Major Concern
Old Sep 26, 2002 | 06:30 AM
  #31
Pimpson's Avatar
yes, gutting the cat on your own can be harmful if not done properly. And the cat mentioned here is the pre-cat or 1st cat. Getting a test pipe that was machined and meant for this application ensures no exhaust leak, it also is 10lbs. lighter than the stock cat.
Old Sep 26, 2002 | 06:44 AM
  #32
bahamut's Avatar
Originally posted by BostonLancer
MIL Eliminator will only trick the computer to stop displaying the Check Engine Light for the O2 malfunction, I will not fix your Air to Fuel Ratio.
You need to open up your air by using an high flow intake.
That's not actually true.
The O2 simulator will bring a constant voltage reading on the 2nd sensor. It's enough to trick the ecu that the 2nd O2 sensor is within performance perimeter. Thus, the A/F will be back to normal, so the 1st O2 sensor doesn't get all confused from all of its reading.
Old Sep 26, 2002 | 09:12 AM
  #33
cyrax5709's Avatar
The way I gutted it was by disconnected the exhaust from beneath and used rebar and a screw driver to hollow out the middle then used the screw driver to scrape out the rest, I wasnt very forceful with it once I got the main hole made. I agree that no one should try this...the only reason I did it was because Im low on cash...and obviously it doesnt take any to do it yourself....does anyone know where I can get an 02 simulator ?
Old Sep 26, 2002 | 09:28 AM
  #34
bahamut's Avatar
http://www.miragetuner.com/howto/o2.html
email the author of the O2 mod . . . if you have any Q?
If I still have spare parts, I can send them to you if you provide a Self addressed Stamped envelope. Just PM me.
Old Sep 26, 2002 | 09:31 AM
  #35
cyrax5709's Avatar
Should that balance the A/F ratio back out?
Old Sep 28, 2002 | 11:36 AM
  #36
bahamut's Avatar
Yes. The 2nd O2 sensor won't send a signal for the 1st O2 sensor to correct itself. It will give a constant signal of little leanness or richness (can't remember).
But I don't know the voltage on the lancer . . . if it's the same.
Old Oct 2, 2002 | 04:56 AM
  #37
cerfur's Avatar
man im tellin you hook up the spark plug!
ruarctb
Lancer Troubleshooting
11
Apr 12, 2016 10:59 AM
FASTER345
Mar 25, 2015 05:52 AM
xcelr8
12
Jan 24, 2010 08:27 AM
EvoDom
Apr 6, 2009 01:54 PM
joeymia
Jul 29, 2005 03:55 PM
