Went to the Dyno...
Old Feb 17, 2006 | 12:20 PM
  #31
Robert_K's Avatar
Well I have everthing install. The mods I did I consider all the "Best Bang for the Buck N/A Mods". The mods consist of; JWT Pop Charger w/ Heat Shield, UR Ultra Underdrive Crank Pulley w/ Gates belts, Motordyne 5/16" Plenum Spacer and Iso-Thermal Gasket Kit, and APS Cat-Delete Race Pipes. Total for these mods are around $800. Everything you can install yourself or with a friend. I suggest for the Test Pipes you have access to a lift. The lift just make it a bit easier to work under the car.
I have to say I love everything. All these parts helped the car. The power gains are defently there and the exhaust note is much better (IMO). The car runs smoother powerband now also. The Race Pipes do give the note a bit of a rasp but nothing I couldn't live with. I personally think these four mods should almost be considered a Stage I Kit for those that plan on staying N/A.
Overall: I'm very happy with my chooices and very happy I did the research before buying. I'll be back on the Dyno on the 25th to see the gains. Hoping for around 240ish whp and 235ish wtq.
Next on my list are: StopTech Stage II Brake Kit & Nismo Cat-Back Exhaust. Ingalls Engineering (http://www.ingallseng.com/) & I are working on some suspention components.
Old Feb 25, 2006 | 09:32 PM
  #32
Robert_K's Avatar
My baseline numbers are below:
Car: 2003 Nissan 350Z Touring 6sp
Mods: None
Dyno: Dynojet 248/224
Whp: 232.88
Torque: 226.36
Mods: JWT PopCharger, UR Ultra Underdrive Crank Pulley w/ Gates belts, Motordyne 5/16 Plenum Spacer & Iso-Thermal Gasket Kit, and APS Cat-Delete Race Pipes
WHP: 249.45
WTQ: 236.49
Gained 17rwhp & 10rwtq!!!!! All for $800!!!
Old Feb 26, 2006 | 12:00 AM
  #33
aboh6leenz's Avatar
good for you man! your car looks pimp. I wouldnt mind a 350 just to cruise around with it is definately more pimp then the evo. But will hardly ever outperform one.
Old Feb 27, 2006 | 10:40 AM
  #34
A418t81's Avatar
17 whp gain from $800 in mods on an NA car is not bad at all, congrats!
Old Feb 27, 2006 | 10:42 AM
  #35
Robert_K's Avatar
Thanks... Next brake kit, suspention and S/C.
Old Mar 5, 2006 | 06:36 AM
  #36
Robert_K's Avatar
DynoGraph: Baseline Corrected vs. Modded Corrected
Basline Power: Whp: 232.88 Torque: 226.36
Modded Power: Whp: 249.45 Torque: 236.49
Nawawe
Mitsubishi TC-SST Discussion
33
May 30, 2013 09:36 AM
chkmgnt59
Evo X Dyno Results
85
Jul 9, 2012 08:54 PM
Robert_K
Midwest Region
Dec 26, 2005 03:51 PM
Evo11V
107
May 9, 2005 11:07 PM
bo0oost
May 13, 2004 06:40 PM
