Focus RS
Old Jan 27, 2016 | 05:56 PM
  #2386
Robevo RS's Avatar
you wana be a co-driver? I am looking for one. PM
I am open for ideas.
Old Jan 27, 2016 | 06:47 PM
  #2387
Ralliart004's Avatar
Veteran: Air Force
hell yes I am interested!!! I may have a vacation lined up for you if your willing to venture south.
Old Jan 27, 2016 | 08:40 PM
  #2388
Noize's Avatar
EvoM Administrator
Originally Posted by Ralliart004
Quite a few top tier circuit spec Hondas disable vtec (which is the same as mivec wouldn't you agree) to run a big cam 100% of the time to remove the point of failure and support reliability in that platform.
Different. Mivec in Evos is like the i in iVTEC. It's basically just computer controlled cam gear(s). No big lobe on Evos.
I can't imagine ever giving up nearly infinite on the fly cam timing in an Evo. The single Mivec 4G63 in the IX proved its vast superiority over fixed cam gears in the VIII more than a decade ago.
Old Jan 27, 2016 | 09:32 PM
  #2389
WarmMilk's Avatar
isn't it like only like 10ish hp on a stock turbo??
Old Jan 27, 2016 | 10:25 PM
  #2390
RazorLab's Avatar
No I don't agree. It is not like vtec whatsoever.
Low end and midrange gains are the biggest advantage with the adjustability of Mivec.
I did a test back in 2009:
Originally Posted by GST Motorsports
Today I had a couple extra minutes to do a comparison on a Evo 10. I don't think I have seen anyone post the differences that can be had between the 100% factory Mivec maps and some "tuned" Mivec maps.
So after tuning this stock Evo 10 I threw the factory Mivec maps back in and did a couple pulls.
Disclaimer: This is not an exhaustive test. I just had some free time to do a very quick comparison. I actually am planning on showing a more exhaustive test on the mivec maps here very soon. Stay tuned for that.
Dotted lines are with tuned intake and exhaust Mivec maps. Solid lines are with 100% factory tuned intake and exhaust Mivec maps.
I'm only showing up to around 5400 rpm as I have yet (so far at least. ) to see very large gains in mivec tuning up top on a stock 10. Let's just look at the curves from the low to the midrange for now.
At 3000-3500 rpm, there is a 45wtq gain with the tuned mivec maps. At 3900, approx 30+ wtq gains. Other than that large torque increase there are huge gains in the way the torque comes in and carries over through the midrange.
This map I am working on actually has some more room in it from 4000-5500rpm as well. I plan in tweaking it a bit more before I post a more "exhaustive" look at Mivec tuning and it's benefits.
Old Jan 28, 2016 | 04:42 AM
  #2391
Robevo RS's Avatar
ever wonder why that was so important on a car which homologated and designed for racing in rally where the cars must shifting idealy 5500 rpm or even lower ?
Anyhow mivec also works great, stable and reliable. no need to change that either
Old Jan 28, 2016 | 10:07 AM
  #2392
WarmMilk's Avatar
wow, I had no idea it was so much... is it this much of a difference between the Evo 8 and 9 also?
Old Jan 28, 2016 | 10:29 AM
  #2393
Noize's Avatar
EvoM Administrator
Yes. In an VIII, you can install adjustable cam gears and make it effective in a small area, but not global like that.
Mivec is way better. Advance the intake cam (gear) timing down low and retard as needed and desired for cam profile and turbo efficient as rpm increases.
The 4B11 ecu has control of both gears and has a better flowing head, better area under the curve still.
Old Jan 28, 2016 | 10:43 AM
  #2394
ambystom01's Avatar
Guys, you gotta get rid of that MIVEC. It's too complicated, and we all know that if you track the car, you want it as simple as possible. Just a cardboard box with wheels, none of that fancy stuff.
Old Jan 28, 2016 | 10:47 AM
  #2395
Noize's Avatar
EvoM Administrator
Just keep it at idle. Piece of junk doesn't do anything there anyway!
Old Jan 28, 2016 | 10:48 AM
  #2396
WarmMilk's Avatar
ok dude calm down, it doesn't have to be all or nothing...
Old Jan 28, 2016 | 10:50 AM
  #2397
ambystom01's Avatar
Nope, the best track car is a unicycle. There's only one thing to go wrong. Perfect.
Old Jan 28, 2016 | 10:57 AM
  #2398
nemsin's Avatar
Man on 207-mph bicycle humiliates Ferrari at dragstrip
http://www.roadandtrack.com/car-cult...-at-dragstrip/
Old Jan 28, 2016 | 12:35 PM
  #2399
Veteran: Air Force
You really enjoy this...that's good.
Old Jan 28, 2016 | 05:55 PM
  #2400
moparfan's Avatar
http://www.roadandtrack.com/new-cars...asts-hope-for/
