Focus RS
Old Jun 21, 2016 | 12:52 PM
  #3706
ambystom01's Avatar
Originally Posted by Erik@MIL.SPEC
Wait, I'm confused.
Is it 2 out of every 5 people say the Evo has never been crash tested or 2 out of every 5 threads Rob posts in get derailed?
I give this thread two stars. Unofficially.
Well's that a pretty good grade, it's a "not good" rating in Rob's books.
Old Jun 21, 2016 | 08:12 PM
  #3707
whtrice's Avatar
Veteran: Air Force
Morph 2 threads .......... Wear the shirt.
XX small available
Old Jun 23, 2016 | 09:00 AM
  #3708
LetsGetThisDone's Avatar
Power output seems erratic. Kaizen has also verified this. Pretty lame. Can't wait to see what tuning can do for it. I would be considering this car if it wasn't for these power delivery issues, and the currently questionable RDU...
http://www.focusrs.org/forum/9-focus...mile-et-s.html
Old Jun 23, 2016 | 09:35 AM
  #3709
nemsin's Avatar
The 2016 Ford Focus RS is powered by a 2.3L EcoBoost 4-cylinder that delivers 345 horsepower and 324lb-ft of torque under normal conditions, but the new Focus RS also has an overboost mode that allows this motor to make 347lb-ft of torque for bursts of up to 15 seconds at a time. http://www.torquenews.com/106/how-mu...345hp-focus-rs
I suspect the "variance" is when in or out of overboost. Either that, or the ECU is dropping people into limp mode.
Old Jun 23, 2016 | 09:51 AM
  #3710
Over boost shouldn't be effecting peak power. That is noted in the thread.
Old Jun 23, 2016 | 09:56 AM
  #3711
nemsin's Avatar
I don't see how it couldn't affect peak power. More boost = more power. No?
Old Jun 23, 2016 | 10:02 AM
  #3712
Robevo RS's Avatar
http://www.carbuzz.com/m/Article.aspx?Id=34145
Old Jun 23, 2016 | 10:10 AM
  #3713
nemsin's Avatar
Originally Posted by Robevo RS
Maybe its just the camera, but that RS paint doesn't look like the Stealth Grey to me.
Old Jun 23, 2016 | 10:21 AM
  #3714
The extra boost is applied down low and through the mid range. It doesn't carry out the top of the rev range. That's how the ST models are anyways.
Old Jun 23, 2016 | 10:32 AM
  #3715
nemsin's Avatar
Right but this guys was saying "The second time down the track I noticed my car was only making 17 or 18 psi in all gears including 3rd and 4th. I couldn't video it with my phone and forgot my GoPro headrest mount, but I was able to have a passenger video it after I left the track and it was still doing the same thing on the highway. When I would row through the gears, at other times when I would stab it in a single gear the car would see 22 or 23psi on the factory gauge. http://www.focusrs.org/forum/9-focus...mile-et-s.html
So I think its the overboost that is being inconsistent.
Old Jun 23, 2016 | 02:52 PM
  #3716
moparfan's Avatar
The overboost is for 15 secs at a time, but we have no idea for how long that period will reset when under repeated stress. Overboost may be present at the beginning of a session and slowly fade away as the ECU protects itself.
Old Jun 23, 2016 | 03:14 PM
  #3717
RazorLab's Avatar
It's Magnetic grey which you can get as well in the UK. You can also get Magnetic Grey in the USA on Focus ST, Fiesta ST and the normal models as well, just not the RS.
Here are the two greys:
Old Jun 23, 2016 | 03:15 PM
  #3718
RazorLab's Avatar
Overboost function is separate from the ECU protection routines in the ST ECU. I don't see it being much different in the RS.
Overboost was one of the first things I turned off when tuning my Fiesta. All the boost all the time.
Old Jun 24, 2016 | 07:19 AM
  #3719
Noize's Avatar
EvoM Administrator
Independent test 3420 lbs, 3/4 tank of fuel 60/40 distribution.
http://www.focusrs.org/forum/9-focus...hts-my-rs.html
Old Jun 24, 2016 | 07:47 AM
  #3720
RazorLab's Avatar
Seems inline with what I posted if you factor in fuel weight. 1 gallon of gas equals 6lbs roughly.
