Official Winged Warrior Ii. (2006) Merged
Originally Posted by smokedmustang
So you sprung a leak, AND couldn't put up a tent? You just have bad luck! This time, why dont you just velcro a sleeping bag on yourself, cut holes in it for arms and legs, and just fall down when you are tired! Forget the tent this time!
...well, it was on the way there, by the time I got there you were all asleep except twidledee and twidledumb, i was so mad. Actually i dk what happen but my slave cylinder for my clutch was leaking and it drained my clutch fluid resivoir, so that was fun calling for AAA at 11 and waiting til 1am for them to come
Originally Posted by Eclipse2Lancer
Semi, Trailer....all the same. I am scared of NOTHING! It's gonna come down to driver skill and seat time anyway I think. We better have some dudes with good seat time, and drive their cars like it is an extension of themselves.....kinda like Zen driving.
Regardless.....Team Import will bring it!
Now it sounds like you are talking about me...
Just think, I had my Stock Lancer OZ on Stock Tires, and still pulled in a Low Time. This Year I have Upgraded my tires and wheels to give me more lateral Traction around the corners. I just hope I get the chance to prove what I can do with my OZ. Maybe I need to see about bringing my HomeBuilt GoCart to get the Lowest time...
L8R, Shado
DJ Lost
L8R, Shado
DJ Lost
L8R, Shado
DJ Lost
L8R, Shado
DJ Lost
L8R, Shado
DJ Lost
I'm personally just hoping my clutch lasts until after the competition.....its still stock at 36k miles and is going to need replaced this year for sure after stomping around at a few competitions.
I had a questions.....when will you know what the specs are for each class? It will determine a lot on what further upgrades i might try to squeeze on the car between now and then. Race tires...power mods....suspspension...etc.
Which isn't much....maybe tape on a homemade number or something.
You will need all of the above, as there are 6 events which require a little of everything.
Fair enough.....i just didn;t know if there was some sort of advantage to running in a lower class if jumping up to the next class meant running against substantially faster cars......i'm not going to be running 500hp or anything by the time the event rolls around. I'll be lucky to have 400. Might have to stiffen the suspension a bit more and get racing tires if nothing else though. I already have 2 of the yokohamas burned off...haha
If you are going to spend $ on a mod.. make it tires. (anything else you do.. stiffer suspension, sway bars, etc.. isn't going to do as much good as it can without good enough tires to transfer it through anyway)
The Toyo Proxy RA1 is an R compound roadrace tire, and because of its sidewall design also makes for a good tire off a drag launch. (whereas a Hoosier R compound for roadracing/autocross might be a little faster on the autocross course, its going to suck on a drag run)
Jon K
Jon K
One More thing.. if my vote counts for anything.. I say let people run any tire they want to.. but at tech it gets stamped, and you have to run that tire for the whole event.
If a 900HP Vette wants to run drag tires and run an 8 second 1/4th pass, thats fine, but make him put up with the wrinkle wall on the autocross course and in the slalom.
Jon K
www.racerjon.com
Jon K
www.racerjon.com
Jon K
www.racerjon.com
Jon K
www.racerjon.com
Jon K
www.racerjon.com
Jon K
www.racerjon.com
