E-Brake down, Brake light on???
Old Jul 2, 2007 | 11:57 PM
m4tt VIII's Avatar
As the title says, my e-brake is down and my brake light is on... i turned the car off then back on, so on so forth, tried pulling it up and down but as i was driving the brake light stayed on. Any help would be appreciated. Thanks -Matt
Old Jul 2, 2007 | 11:59 PM
TSiAWD666's Avatar
Check your brake fluid level as a first step.
Old Jul 3, 2007 | 07:29 AM
grillpt's Avatar
Yeah, most likely your low on fluid causing the light to say on. Also, if you are low on fluid you may need pads soon.
Old Jul 3, 2007 | 07:41 AM
m4tt VIII's Avatar
thanks ill be sure to do that anything else?
Old Jul 3, 2007 | 08:00 AM
lancersibling's Avatar
if thats not it, you might be receiving a signal from the e-brake sensor under your center console just in front of the brake assembly.
Old Jul 3, 2007 | 08:03 AM
SEEnoEVO's Avatar
probably low fluid. Brakes will probably need to be replaced soon. As they wear, the pistons move further out which takes more fluid. Just happened to me.
Old Jul 3, 2007 | 09:44 AM
sharkm87's Avatar
the light is in relations with the sensor under the center console..i dont think i thas anything to do with break fluid.
unscrew the screws in the center console and take itout, physically inspect the sensor by engaging and disengating the brake lever to see if the little metal peice is connecting as it is suppose to....i'm sure with a visual inspection you can figure out whats wrong, or maybe the wire attached to the sensor has disc. itself.
Old Jul 3, 2007 | 12:18 PM
evo150's Avatar
check the thickness of the brake pads before adding brake fluid. most likely its time for new pads
Old Jul 3, 2007 | 12:25 PM
bluebyu36's Avatar
last time that happened to me my brake light and battery light would not go off,it was my battery and alt died on me..
Old Jul 5, 2007 | 10:17 AM
spooch's Avatar
my brake fluid level caused same problem
saytheb
Jan 13, 2010 01:40 AM
bboy_RES
10
Mar 15, 2009 08:17 PM
raytrix
Jun 23, 2008 02:44 PM
Bigjoeski05
14
Aug 30, 2006 10:18 AM
WillEatUrSTi
Mar 18, 2006 11:12 PM
