Important ECU Thread Links
Old Aug 25, 2009 | 01:56 PM
chaotichoax's Avatar
I closed the other thread and started this as the OP was no longer active on EvoM. Please PM me with any thread link addition ideas. I want this to be as complete and useful as possible for all of us.
**********ECU WIKI PAGE**********
ROM Patches:
Latest Tephra Patch:
https://www.evolutionm.net/forums/ec...hramod-v7.html
tephra mod v7 - tephra
https://www.evolutionm.net/forums/ec...ur-answer.html
v7 questions & answers
Legacy (EOL) Tephra Patches:
https://www.evolutionm.net/forums/ec...d-v5-10-a.html
tephra mod v5.10 - tephra
https://www.evolutionm.net/forums/sh...d.php?t=297825
PATCH: NLTS + Valet + KnockCEL by Tephra
https://www.evolutionm.net/forums/sh...ight=byte+load
96940011 05 EVOVIII ROM: Known Patches
Additional ECU Features:
Speed Density
https://www.evolutionm.net/forums/ec...ched-roms.html
How To: Speed Density - Scheides
https://www.evolutionm.net/forums/ec...y-patches.html
Speed Density patches - jcsbanks
Boost Control:
https://www.evolutionm.net/forums/sh...d.php?t=293981
Direct ECU boost control by mrfred
https://www.evolutionm.net/forums/sh...d.php?t=288408
Fine tuning Load based boost control to prevent weather based boost variation by mrfred
https://www.evolutionm.net/forums/sh...d.php?t=276674
HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid - Evo_Kid
https://www.evolutionm.net/forums/sh...d.php?t=227006
HOW TO - Control boost using ECUFLash and the stock boost solenoid - Evo_Kid
OBD/Emissions
https://www.evolutionm.net/forums/ec...us-mrfred.html
forced obd inspection pass - acamus & mrfred
https://www.evolutionm.net/forums/ev...-canister.html
how to: egr/emissions system removal - fostytou
https://www.evolutionm.net/forums/ec...solenoids.html
disabling egr/fuel pressure solenoids - fostytou (Page 9/10 preliminary how to with pictures)
https://www.evolutionm.net/forums/ec...ml#post6613499
Forced O2 heater pass
Raising Load Limits:
https://www.evolutionm.net/forums/ec...nge-638-a.html
doubles fuel cut load limit - mrfred
Advanced Logging:
https://www.evolutionm.net/forums/la...o-evoscan.html
Logging an AEM UEGO w/o a serial cable - darkmitsu
https://www.evolutionm.net/forums/sh...d.php?t=259595
JDMMAP sensor set-up - mrfred
https://www.evolutionm.net/forums/ec...ial-cable.html
log afr from lc-1 w/o a serial cable - mrfred
https://www.evolutionm.net/forums/ec...e-logging.html
Manifold Air Temp Logging - mrfred
94170008 ROM 2 byte load mod for dummies (like me by A418t81
https://www.evolutionm.net/forums/sh...hlight=dummies
Evo IX 2-byte Load & Lean Spool for Dummies by Pd1
https://www.evolutionm.net/forums/sh...d.php?t=259494
log WGDC in EvoScan - mrfred (good info on solenoid TBEC)
https://www.evolutionm.net/forums/ec...ging-help.html
Troubleshooting AEM UEGO wideband logging issues - tips and tech info
Tuning Tips and Tricks:
How To's
https://www.evolutionm.net/forums/sh...d.php?t=302895
How to Tune an Evo by nj1266
https://www.evolutionm.net/forums/ec...-ecuflash.html
Visual Training - How To: Tune an evo with Ecuflash - recompile
https://www.evolutionm.net/forums/ec...s-how-tos.html
ecu pin removal/installation/map switching harness how to - mrfred
Virtual Dyno Simulator
https://www.evolutionm.net/forums/ec...simulator.html
Virtual Dyno Room Simulator - jack of trades
Map Smoothing Tool
https://www.evolutionm.net/forums/sh....php?p=6053943
Autosmoothing tool by Jumperalex
Injector Tuning
https://www.evolutionm.net/forums/ec...upermerge.html
Consolidated info from Fast Freddie
Start-up Fuel and ISCV Tables
https://www.evolutionm.net/forums/ec...cv-tables.html
Thread from Jamie at Dynotech Tuning
Lean Spool Tuning
https://www.evolutionm.net/forums/ec...s-enabled.html
lean spool tuning - appauldd
Advanced Tuning
https://www.evolutionm.net/forums/sh...d.php?t=327185
official 2 byte load w/ mut address - jack of trades
https://www.evolutionm.net/forums/sh...d.php?t=201146
ECUflash tutorial for beginners - EFIxMR
https://www.evolutionm.net/forums/ec...ble-found.html
Knock control - load vs RPM table found - jcsbanks
https://www.evolutionm.net/forums/sh...jector+scaling
Injector Scaling by various members
https://www.evolutionm.net/forums/sh...d.php?t=249388
MAF Scaling by SophieSleeps
https://www.evolutionm.net/forums/sh...t=mivec+tuning
Mivec Tuning by John Bradley the mivec guru (Page 10 and on are more useful information)
https://www.evolutionm.net/forums/ec...cy-tables.html
Turbo Efficiency Tables
https://www.evolutionm.net/forums/ec...ter-spool.html
Tuning for Faster Spool
https://www.evolutionm.net/forums/ec...-searched.html
Tuning for POOR Cold Idle
Advanced ECU Development
https://www.evolutionm.net/forums/ec...e-lookups.html
beginners guide to ecu table lookups - advanced material - logic & many more
Again, any additional links that you think should be here PM me or post in this thread.
Old Nov 4, 2009 | 07:46 AM
reserved for text
reserved for text 1
Old Nov 4, 2009 | 08:08 AM
MR Turco's Avatar
Great idea
Old Nov 4, 2009 | 06:34 PM
MR Turco's Avatar
I know this is missing some important threads so please post. I did a little organization to break ti up a little bit but feel free to make any suggestions. This thread is to help you guys so i can change whatever to fit what you guys want.
Old Nov 4, 2009 | 07:17 PM
Appauldd's Avatar
How about my cold start/idle thread? It has a lot of coverage.
Old Nov 5, 2009 | 01:28 AM
Evo_Jay's Avatar
Nice update.
if I think of any threads that should be added, ill be sure to let you know.
edit- shouldn't you just condense the two 'advanced logging' sections? just a thought
And injecor scaling and maf scaling should be under a "fuel" category, IMO.
Old Nov 5, 2009 | 04:59 AM
MR Turco's Avatar
Can you post links and i will gladly add them. Thanks guys!
Old Nov 22, 2009 | 08:09 AM
CMB's Avatar
CMB
The tutorial on how to scale your Maf isnt working!
Old Nov 30, 2009 | 03:38 AM
MR Turco's Avatar
Works for me, let me know if you still have issues.
Old Dec 24, 2009 | 08:49 AM
wfochris's Avatar
I vote for jumperalex's autosmoothing excel sheet to be added
Old Dec 27, 2009 | 02:14 AM
Ludo's Avatar
Good idea,thanks
Old Dec 27, 2009 | 03:53 PM
Evo_Jay's Avatar
This thread should be added
Old Dec 27, 2009 | 06:17 PM
Evo_Jay's Avatar
opps double post, please delete
Old Jan 12, 2010 | 10:04 PM
Appauldd's Avatar
Please add....
