are the torque limiters tables used on GSR ?
Old Aug 25, 2009 | 03:57 PM
GTR2009's Avatar
are the torque limiters tables used on GSR ? because I get very bad launches and the RPM drops to 2500rpm
Old Aug 25, 2009 | 03:59 PM
GST Motorsports's Avatar
Airflow / Torque won't bring the RPM's down, it just cuts boost to wastegate and makes the car idle high, RPM dropping is probably from bogging the launch.
Old Aug 25, 2009 | 04:05 PM
GTR2009's Avatar
you mean clutch slip ? No I don't have clutch slip. I also completly disable the ASC
I wait for the stationary rev limiter to reach 2-3 times then I dump the clutch, sometimes it starts hard with a lot of wheelspin.
well if the torque limiters cuts boost then it should be reason why it does not have enough power to break the traction
Old Aug 25, 2009 | 04:52 PM
Does it throw a cel and put you in limp mode? (idles high)
Old Aug 25, 2009 | 05:03 PM
GTR2009's Avatar
No, I don't get any CEL or limp mode.
Old Aug 25, 2009 | 05:06 PM
Then it's neither the Torque nor Airflow limiter.
Old Aug 25, 2009 | 05:30 PM
GTR2009's Avatar
It is very annoying that sometimes it launches hard and most of the times it drops the RPM and I get 0-60ft in 2,3sec., in the same location on dry tarmac
Old Aug 25, 2009 | 05:31 PM
Are you sure you just aren't bogging the launch?
What RPM are you launching at?
Old Aug 25, 2009 | 05:35 PM
GTR2009's Avatar
I launch the car from the stationary rev limiter 5400rpm, should I raise the staionary rev limiter?
I am not sure what you mean with bogging (I can't speak very well english).
Old Aug 27, 2009 | 09:09 PM
droppinbottom's Avatar
You are dumping the clutch too fast and when it grabs it brings the rpm's down.
You need to be able to slip the clutch a little to get the car rolling and then let off the clutch completly. Don't slip it too much or you will burn/glaze the clutch.
Old Aug 28, 2009 | 02:16 AM
GTR2009's Avatar
Last time when I let the clutch slip I got a lot of clutch smoke (It's a stock clutch on a tuned evo), I don't know why is this problem on evo, subaru's starts perfectly if you dump the clutch.
Old Aug 28, 2009 | 05:06 AM
GTR2009's Avatar
I wonder why the guys from Vishnu are talking about a limiter on GSR
And if Pathak had removed the Evo's electronic measures that protect the drivetrain, which limit engine speed during standing-start launches, the quarter-mile would have been even quicker
Disabling the Evolution's stock drivetrain protection would make for even quicker launches, while tweaking its electronic throttle would make it more driver-friendly during daily use.
full article here http://www.edmunds.com/insideline/do...ticleId=125372
PPM
Apr 2, 2015 09:35 AM
GTR2009
Aug 23, 2013 07:13 AM
COBB Tuning
31
Feb 26, 2011 03:48 PM
jamie_v1
11
Oct 21, 2010 08:37 AM
AIK
10
Sep 13, 2010 02:48 PM
