Will EvoScan monitor fuel pressure?
Is there any reason to log fuel pressure, or do people just do an analog gauge for this? I have an inline pump and want to make sure I know if it fails.
Yeah, I meant with an external sensor. I guess this answers my question though. I currently am seeing a lean condition, and am trying to decide what to purchase. It sounds like a classic analog fuel pressure gauge is the way to go instead of trying to monitor it continuously.
You may check this thread:
https://www.evolutionm.net/forums/ev...under-wot.html
Or this one:
https://www.evolutionm.net/forums/ev...ur-engine.html
Not sure if that is what you are experiencing, but I have seen this before.
Or this one:
Tephra- if you're reading this, do you forsee this as a future option for us?
Thanks.
Traction - Got your PM
1) as mentioned already EvoScan can ONLY log whatever sensors the ECU currently has access to
2) fuel pressure is NOT available to the stock ECU
3) You CAN connect additional sensors - they need to output a 0v to 5v range, preferably linear although its upto you and EvoScan to convert voltage into something meaninful
We have identified a number of FREE ADC inputs (ADC = Analogue to Digital Converter, x voltage into a number) on CT9A however I havn't looked properly for CZ4A.
I will be doing this as part of my altmap setup for CZ4A (for my Meth failsafe) so stay tuned.
Cheers
David
Cheers
David
Jovan Caro
Feb 6, 2017 08:03 PM
LT1runner
15
Jan 14, 2008 10:10 AM
rt turbo
Nov 10, 2004 09:32 PM
edtxag
Jul 31, 2004 09:14 PM
