EcuFlash SST tables...
Old Dec 8, 2009, 11:52 AM
GST Motorsports's Avatar
Since I keep getting a ton of PM's about this.....
The SST tables are still being tested.
SST Torque limit 1-3
Clutch A Engage/disengage
Clutch B Engage/disengage
and a couple others.
Good news is I (and some others) have been getting very good results now that we have access to these tables.
I've had a couple MR's with decent power open the clutches on our mustang dyno after repeated pulls (and some even the first pull or so). After some SST table tweaks, no more issues. Also shifts have been tweaked to be more aggressive, etc.
There is also a table that limits lower ignition timing on the MR. Meaning, the ECU will not run under a certain degree, even if you have lower in the main ignition table. You can imagine this can cause a problem on larger turbos, on lower octane like 91. Now that is no longer an issue. You find this here: https://www.evolutionm.net/forums/ev...wer-bound.html
Still looking into some other MR tables.
- Bryan
Old Dec 8, 2009, 12:06 PM
EvoM Moderator
scheides's Avatar
Awesome! keep us posted!
Old Dec 8, 2009, 01:24 PM
HB Speed's Avatar
Exclamation
- Bryan
Like bryan said above:
These tables need more testing before released to the general population please allow us to know what when and why they work before we let people loose on their trannys
As we know more im sure you all will know!
Old Dec 8, 2009, 02:02 PM
lodifreefly's Avatar
- Bryan
Does this mean you found the shift ign retard table and it wasn't the warm up ign retard?
Old Dec 8, 2009, 02:06 PM
LVSBB6's Avatar
This is coming along nicely! keep up the good work
Old Dec 8, 2009, 02:31 PM
Psycho09RA's Avatar
That's great to hear Bryan!
Does this also mean that changing the SST tables is possible on the Ralliart as well?
Old Dec 8, 2009, 02:33 PM
HB Speed's Avatar
ive already got the 2009 and 2010 RA tables ready
and the 2009 / 2010 MR too
Old Dec 8, 2009, 03:00 PM
Psycho09RA's Avatar
Sweet!
Old Dec 8, 2009, 03:08 PM
velocityhead's Avatar
DEFINITELY good news.
Old Dec 8, 2009, 03:14 PM
HB Speed's Avatar
Sweet!
workin on it
we tuned a RA with ETS35r and were working with these to make it handle it !!
Old Dec 12, 2009, 03:20 AM
gunzo's Avatar
shift retard is a function of one of the tables bryan mentioned .. there is no direct table that determines shift retard timing ..
Warmup retard is warmup timing ..
very little is understood because these tables get sent to an address that I can't log .. for now .. so I don't know what it does after that ..
There's a few guys just running these on beta maps that I sent out .. just to make sure there's no weird glitches happening ..
Old Dec 14, 2009, 10:24 AM
Looks like razorlab needs to update the ecuflash definitive guide sticky... per that post:
"Ignition Warmup Retard
This table is used on warmup and also used on the MR SST model for shift ignition retard"
Old Dec 17, 2009, 10:36 AM
kozmic27's Avatar
Are these the same as the Ignition Ceiling and Ignition Floor tables in Cobbs Access Tuner software or is this something in addition to that?
Old Dec 25, 2009, 09:50 AM
LVSBB6's Avatar
Any updates on the SST tables?
Old Dec 29, 2009, 02:04 PM
thrlskr's Avatar
Good news! Thank you for your hard work (GST, HB ,Gunzo and others)!
Quick Reply: EcuFlash SST tables...
