Street Modified update
Old May 19, 2005 | 01:32 PM
  #106
markdaddio's Avatar
ROFLMA!!!!!!!!!Yeah, what he said. big
By the way, what size shoes do you wear?
Old May 19, 2005 | 07:15 PM
  #107
dwx's Avatar
dwx
Originally Posted by 93esp
I will be at Peru next weekend for 3 days.......
Ah okay I thought you were doing the TSSCC test&tune this weekend.
Old May 23, 2005 | 09:03 AM
  #108
vtsnake's Avatar
mark, i have no doubt your car will take sm at nationals with you driving. only comp you should have is when tunnel gets the blower done on his m3. i thinks it's almost done. anyway good luck and i hope you kick sias butt!
Old May 23, 2005 | 11:17 AM
  #109
93esp's Avatar
Originally Posted by markdaddio
So Eric, spill the beans. Did you really decide to run a bigger turbo, and if so, how about a cool anti lag system.
Mark
Yes I am running a large turbo, yes it does spool similar to stock, yes it will have anti-lag and throw flames out the side exhaust.
Old May 23, 2005 | 02:33 PM
  #110
whitet777's Avatar
Please come up to Milwaukee with your beast to show it off at an event.
Tim
Old May 23, 2005 | 02:46 PM
  #111
dwx's Avatar
dwx
Tim do you know if Bill Brenner ever sold his 2.3L EVO? That's a car begging for some 285s and a very good driver.
I was going to make the exhaust from my external wastegate point straight out the hood, but my history with fire and whatnot people might freak out...
Phil
Old May 23, 2005 | 03:05 PM
  #112
whitet777's Avatar
Last I heard (about 2 weeks ago at Big Bear) is that it is still for sale. He wants like $35k for it or something. Ouch.
Phil and fire is a bad thing.
Tim
Old May 24, 2005 | 07:49 AM
  #113
markdaddio's Avatar
Very cool. I can't wait to see it in action. Should be fun.
Mark
Old May 24, 2005 | 10:41 AM
  #114
93esp's Avatar
Yeah, we'll see if I have it tuned up enough to run in Toledo or not. Unfortunately it's not just bolting on a huge turbo - the whole engine combination had to change. If not we'll be running our quick SM Civic that's hopefully running on all cylinders now....
Eric
Old May 24, 2005 | 10:44 AM
  #115
metaphysical's Avatar
Registered User
Just out of curiosity, why not run 285s front and rear and dial in your oversteer with spring rates and swaybars?
Old May 24, 2005 | 11:14 AM
  #116
jbrennen's Avatar
Or with damper adjustments or with alignment...
That's what Eric and Joe and Navid and others (like myself) have done. It's certainly one way to go.
I can't speak for Mark's motivations, but I can think of a few reasons why one might want to stick with (for example) 245s in the rear...
- Running 285s in the rear requires some fender modifications.
- With 285s in the rear, your range of usable alignment in the rear may suffer.
- 285 width tires are more expensive and heavier. If you are going with the popular 285/30R18 size, you're also using wheels which are almost certainly more expensive and heavier.
If you're going to fit 285s and then dial out rear grip to the level of a 245, save yourself a lot of trouble and just stick with the 245s.
Old May 24, 2005 | 01:50 PM
  #117
Mhyrr's Avatar
Phew.. SM will be exciting to watch this year.
I hope to see at least some of you guys at the Nediv this year..
<shameless plug> which opens for registration tomorrow through http://www.nedivsolo2.org/05divisional/ and is scheduled for Jul 30-31 </shameless plug>
and Topeka of course.
Old May 24, 2005 | 02:43 PM
  #118
markdaddio's Avatar
Yes to all of the above. In addition
- with the staggered tire setup, the front and rear build heat more evenly, creating a more consistant balance from beginning of run to the end.
- The mid corner off understeer that we are trying to avoid, is much easier to avoid with a smaller rear tire. (since the inside rear isn't really doing much if anything at that point)
- running a smaller rear tire allows me to run a more transition friendly alignment.
Hope that sheds some light on my thinking.
Mark
Old Jun 2, 2005 | 10:18 PM
  #119
chrisw's Avatar
Mark, I don't know what year of EVO you have... what year is it?
If it's not a RS or an '05 have you considered upgrading the front diff?
Old Jun 3, 2005 | 03:15 AM
  #120
markdaddio's Avatar
Chris,
My car is an 05 rs. I have been working on the weight thing, and have now got it down to 2950 in race trim. With A/C still in the car for driver comfort, as I will not be trailering this to events this year. I am now thinking that with a little work I should be able to get the car under 2900 while retaining the A/C. The next two weekends will tell the tale.
Mark
