What do you guys used for Suspension and Brake setup for track?
Old May 18, 2006 | 07:27 PM
S1monLM's Avatar
Please post em here!
Old May 18, 2006 | 08:03 PM
EMR8's Avatar
Hawk HP Plus
Goodridge lines
ATE Superblue
Buddy club Racing Spec
Perrin Rear sway bar
Corner balanced and aligned
Simple!
Old May 18, 2006 | 11:34 PM
Stop&TurnFreak's Avatar
Note Sig.
Old May 19, 2006 | 05:11 AM
kingkyle's Avatar
1 Lines / Fluids / Pads
2 R tires ex RA-1's / Hoosier / Nitto
3 Rear sway (25mm)
4 Coilovers Set of JIC's will do... cheap and good (camber plates, camber is importaint
5. Track time... prob the most importaint item on the list.
Old May 19, 2006 | 06:00 AM
ovenmit331's Avatar
Works Lines (replacing before next track event for fear of failure)
Ferodo DS2500 Pads (good for street and decent for track)
Baer Eradi-speed 2-piece rotors all around
ATE SuperBlue fluid
RRE Rear sway bar on middle setting
Works Croxx Plate II
about to have a set of custom tuned JDM Apex'i N1 coilovers installed
about to buy and install Brake Air Guides
wanna buy the GTSpec Trunk Cage
Old May 19, 2006 | 06:49 AM
Richard EVO's Avatar
Muellerized JIC Coil overs and rear sway bar - set alignment with 1 degree more negative camber on outside wheels, depending on if track is CW or CCW
Project mU front and rear brake pads, Centric slotted front rotors, Motul 600 brake fluid.
Old May 19, 2006 | 07:13 AM
thechoc's Avatar
This is more of a backroad setup, but I've done well over ten track days with this spec.
Ferodo DS2500 Pads
Goodridge SS brakelines
Motul 600
alignment
see sig
Old May 19, 2006 | 07:52 AM
hagakure's Avatar
Goodridge Lines, ATE Blue Fluid, Hawk DTC-60 pads, RacingBrake Front Big Brake kit, rear two piece rotors, also with DTC-60. Amazing amazing set-up, fade free, reliable.
Old May 19, 2006 | 07:57 AM
1NastyEvo's Avatar
- Goodridge S/S lines
- Motul RBF 600 brake fluid
- Cusco type 40 rear strut
Oh ya and stock suspension/brake pads lmao.
Worked pretty damn well at willow springs horse thief mile.
Old May 19, 2006 | 09:18 AM
Kayaalp's Avatar
I use the stock suspension on my 2003 Evo VIII. A proper 4-wheel alignment with careful camber, castor, and toe settings transformed the car from an understeery beast to a very well-balanced cornering machine. I'm looking into puttng on a slightly stiffer rear bar just to eliminate that very last whiff of understeer under power. But it hasn't been a priority.
As for brakes, the stock calipers are just fine. I've replaced the stock rotors with custom 2-piece floating rotors with directional vanes. And I swap out my street pads for real track pads, like Carbotech XP-9/10 or Performance Friction PF-97. I also use proper high-temp fluid, like Motul RBF 600. And I've thrown on Goodridge s.s. lines just for the hell of it (I noticed no difference between these and the stock rubber flex lines).
Emre
Old May 19, 2006 | 10:25 AM
992gnt's Avatar
How are you adjusting caster Emre?
My setup:
SS lines
ATE Blue fluid
Ferodo 2500 (street)
Ferodo 3000 (front only - track)
Stock rotors
Muellerized JIC's
RS trunk bar
25mm rear sway bar
-2.5 front camber, -.8 rear camber, 0 toe front and rear
Old May 19, 2006 | 10:41 AM
Kayaalp's Avatar
Oops! I was thinking of my dedicated track car. On my street Evo, I don't have adjustible castor. I only was able to adjust camber and toe. But it made a huge difference, especially at corner entry.
Emre
Old May 19, 2006 | 10:46 AM
jid2's Avatar
Brakes:
- Goodridge Lines
- ATE Super Blue or Motul RBF 600 depending on which bottles are in my garage at the time
- Ferodo DS 2500 pads, but I want some PFC 97's
- Removed dust covers from front rotors
- 2 inch diameter hose for brake ducting
Suspension:
- Hotchkis Springs
- 25 mm Progress rear bar set in the middle
- Tein front camber plates
- Lots of ureathane bushings I haven't had time to install
- I'll be running Ohlins coilovers once I can get ahold of some
- -2.9 front (maxed out) 1/16th toe out. -1.8 rear with no toe
Old May 19, 2006 | 10:56 AM
992gnt's Avatar
Emre
Ahh, I thought you found a secret adjustment somewhere. These cars do benefit hugely from a proper setting up, that's for sure.
Old May 19, 2006 | 02:11 PM
RazorLab's Avatar
Performance friction 2 piece front rotors
PMU MAX900 front pads
PMU Titan Kai rear pads
Motul 600 fluid
RRE braided lines
Front dust shields off
Apexi coilovers
Whiteline rear sway
Rear arm bushings
-2.7 front camber
-1.3 rear camber
255/40/17 RA1s
The PMU MAX900 are the best pads I have used so far in the last 1.5yrs of tracking the evo. The best thing of all is that they are cheap.
Did great in 100F+ ambient heat at buttonwillow yesterday. No brake fade or brake feel change. Until my headgasket shut down the party. 230F water temps and 280F oil temps = all my warning lights on my greddy gauges coming on. Not fun luckily I caught it before I had to tow the car 280miles home.
