More 6spd carnage!!
No worries. Since we're reasonably close, I thought I'd offer. Hate to lose much of the best time of the year for car use, but John S. is pretty quick on turnaround, so you might only be down a little while.
If anyone is looking for a modified 6 speed in perfect condition, still at TRE (would be shipped directly to you from TRE) please look here: https://www.evolutionm.net/forums/sh...d.php?t=214092 Thanks, all.
I probably have close to 300 launches, since most of my autocrosses at the beginning were non-SCCA where I got 6 runs and almost always had room for a full launch. I dont' know if the launches would have any effect on 4th going bad, though. I think it was mostly my recent change to always using 4th all the way around both local tracks.
500 road course miles, 200+ drag runs (100+ low 12s) all with a powershift on the 3-4, and about 20 autocrosses, although that's never higher than 3rd.
Originally Posted by razorlab
Do a tranny cooler.. now!
The way we finally reduced the failure was to run shockproof heavy gear oil and use stock like clutchs and pressure plates. Maybe 6 speed Evo owners should try using the shockproof heavy gear oil and see if that helps.
Transmission coolers and tight tolerances are key.
Well, since that was the best pad I've ever driven on, it felt like a huge upgrade compared to the stock pads. Then again, the majority of my fast driving yesterday was done on the RT615s. I got no good laps on the V710s that were cording, so maybe I haven't yet had the chance to overpower the HP+'s since my r-comps were out of commission. Regardless, these pads felt way way better than my stock pads, so I'm excited. If the Hawk Blues are that much better, then I'm even more excited!
I use the Hawk Blue pads on my race car and they are great on a light weight car around 2500-2800 lbs. On the Evo, however, they will be overworked. There is a better hawk compound than the Blue, but its name escapes me right now. It is specifically designed for heavy cars like our Evos.
Yah, until you use your car on a real road course and have to brake hard from 130mph, then you really have no idea what your brakes are capable of...you should definitely get to a road course and try it out. It blows drag and auto-x away, because it makes full use of every aspect of the car: handling, braking, acceleration, top speed, and the DRIVER MOD.
And once you try actual door to door racing, thern hotlapping becomes pale by comparison.
Originally Posted by TTP Engineering
Yeah, like that is gonna happen.
I have been road racing since 2000 and I have three competition licenses, SCCA, NASA, and TCRA. How many do you have from road racing organiztions?
How can you tell if shockproof heavy will work or not, if you did not try it?
