More 6spd carnage!!
TTP, are you saying you had the same symptoms as me and yours looked like that? My gearbox out of the car now and is getting shipped to TRE this week so I will find out soon enough.
The gearbox oil had a small amount of metal chunks in it.
Originally Posted by Jeff_Jeske
I have well over 1000 HPDE miles on my 5 speed and I run Pennzoil Synchromesh. I change the stuff every 15k miles but it normally still looks like new.
I've drained my synchromesh several times and the fluid looked clean each time as well. I would think that Mitsu put out the factory viscosity specs for good reason though.
Originally Posted by marksae
I probably have about the same # of track miles on my car too and it's used Synchromesh for all those miles. I believe razorlab had 10 track days before he had problems w/ his tranny. So if you talked to him after his 9th track day, he probably would have said BG2 worked great.
Jon told me that if I am using the car like this, I really need to be changing all the drivetrain fluids before every event, just like I change my engine oil and bleed my brakes before every event. You better believe I will be doing that from now on.
Once any oil burns it doesn't work so well. The gearbox isn't like the motor where oil gets dirty from carbon, etc. If the oil is a darker color then when you put it in, that means its getting really hot.
Smike
628
Oct 27, 2024 04:39 AM
MagicManRed
596
Dec 9, 2020 07:59 AM
Smike
63
Apr 29, 2019 07:27 AM
