Tranny Fluid
Old Sep 20, 2006 | 06:16 PM
  #76
VR4orceCJ's Avatar
Cool
The pump was mounted using two heavy machine screws. One drilled through the bracket for the FMIC and the other straight into the frame rail. It was very secure when I was done. If anyone would like higher res photos of the setup PM me an email address to send them to.
In regard to oil temps...use good thick synthetic and change it often put the biggest most efficient cooler you can on there and you should be good. SCCA won't let me so I just change the oil often...gear and engine.
Old Sep 24, 2006 | 04:00 AM
  #77
JT-KGY's Avatar
Originally Posted by razorlab
and what is the GL rating and weight and viscosity of BG2?
BG2
SAE 75W80
API GL-4
What is the rating of Mitsubishi Dia Queen Super Multi Gear Oil?
Isn't this too thin for Evos (per manual's spec)??
Why does everyone (esp RRE) recommend the BG2's??
Originally Posted by Mike01gsr
Have any of you guys tried the Amsoil?
http://www.amsoil.com/StoreFront/mtg.aspx
I ran this for about 8k miles.. works just fine... until I switch to Penn Syncromesh..
then shifting got smoother but I also start to grind 3rd gear sometimes..
Old Sep 29, 2006 | 09:40 AM
  #78
redvolution's Avatar
BG2
SAE 75W80
API GL-4
The NorCal distributor (Fleming Distribution) for BG Products told me Syncro Shift II is 75w85.
From BG's site:
BG Syncro Shift® II is a gear lubricant specially formulated for front wheel drive manual transmissions. It does not sacrifice any performance as does engine oil, ATF or conventional gear oil. It provides required thermal stability, low-temperature fluidity, hot rattle suppression, noise dampening at operating temperature, outstanding extreme pressure characteristics, shear stability, smoother shifting characteristics, wear reduction (synchronizer, gears, bearings, shift fork), seal compatibility, and reduced maintenance costs.
Old Sep 30, 2006 | 09:36 AM
  #79
Mike01gsr's Avatar
Well just recieved my case of Motul gear 300. Purchased it from
www.performanceoilstore.com. Good experience with them and
if you buy a case you get 7% off and free shipping. Almost 165
for case.
Old Sep 30, 2006 | 09:38 AM
  #80
Mike01gsr's Avatar
BTW razor how is the oil cooler set-up coming?
VR4orceCJ I would love to see some hi-res pics of
your cooler set-up, you can send them to Mike01gsr@zoominternet.net
Old Sep 30, 2006 | 06:03 PM
  #81
JT-KGY's Avatar
But isn't Motul 300 GL-4/GL-5??? Something we cant put in our transaxles??
Old Sep 30, 2006 | 06:21 PM
  #82
hondafan's Avatar
Originally Posted by atlvalet
I don't race (yet) like some of you, but I have switched to a MOPAR fluid, which is GL-4 75W-85 like the SuperDiaqueen, but it's fully synthetic. Basically, it's repackaged Castrol SynTorq.
i use this exact same fluid! it works great, smooth shifting, lasts pretty good since it's synthetic. it's just repackaged castrol syntorq LT, since castrol doesn't sell it in the states, however, many european race teams run it in their trannies. dodge sells it for the tranny fluid for the diesel truck manual tranny, the NV4500 tranny i think.
Old Sep 30, 2006 | 09:28 PM
  #83
Mike01gsr's Avatar
GL-4 and GL-5 why don't you think we can use it?
Old Oct 1, 2006 | 04:05 AM
  #84
hondafan's Avatar
hasn't GL-5 been proven to be corrosive to brass parts like synchros?
Old Oct 1, 2006 | 09:24 AM
  #85
Mike01gsr's Avatar
Well I would think if it's rated for GL4 and GL5 it wouldn't be corrosive. I highly
doubt a company like motul would give it a gl4 rating if it was going to mess
up some gear boxes.
Old Oct 1, 2006 | 03:28 PM
  #86
Mike01gsr's Avatar
I'm going to double check with one of the U.S. motul distributers to see if it's ok
to use in our car. I can't seem to find a e-mail for motul on there website but
maybe I'm just retarded. From what i've read from little blurbs on the net alot
of people have recommended it for the evo so we will see.
Now I'm paranoid thanks guys...lol
Old Oct 1, 2006 | 05:01 PM
  #87
hondafan's Avatar
i'll try and find the post by GEARS(jon at TRE)where he states not to use GL-4 and GL-5 rated fluid in the trnny, just GL-4. he says it's like a spark plug company selling you a plug that is good for a 7 or an 8 heat range. he pretty much said there isn't a one size fits all fluid either.
Old Oct 1, 2006 | 05:11 PM
  #88
Mike01gsr's Avatar
Well not to take anything away from Jon at TRE but he recommened BGII also and it's to thin to run in the MR tranny. Again I know he knows his stuff inside and out but I will need more concrete information other then his opinion.
Old Oct 1, 2006 | 05:19 PM
  #89
hondafan's Avatar
how about in the manual where it says diaqueen super multi gear 75-85 GL-4 or an "exact" equivilent? that's good enough for me and the reason i searched and searched to find a fully synthetic 75-85 GL-4 to use, i've been using it for around 30,000 miles without a hitch, better than the stock fluid in my opinion.
Old Oct 1, 2006 | 05:22 PM
  #90
Mike01gsr's Avatar
What are you using? BGII? Have you read the thread where two people using blew 4th gear? Do drive your car on a road course?
