Tranny Fluid
Old Oct 13, 2006 | 04:01 AM
  #106
WarmPepsi's Avatar
oem fluid, imo.
Old Oct 13, 2006 | 06:39 AM
  #107
bullfrg's Avatar
Penzoil Synchromesh for the tranny and Mitsu Diaqueen for the TC and rear dif.
Old Oct 13, 2006 | 08:20 AM
  #108
DaWorstPlaya's Avatar
I would highly recommend OEM fluids but in your case, since you don't track your car, you could get away with using Pennzoil Synchromesh or BG Synchroshift in the tranny.
Old Oct 16, 2006 | 07:34 PM
  #109
NDgsx's Avatar
Originally Posted by VR4orceCJ
A few pics of the gear oil cooler I installed today. This is the SCCA T2 spec unit (have to use spec parts). Learned a few things and adjusted as needed. More later...
Do you have to run the tube style of cooler? I found much better results in my eclipse going from that style of cooler to one of these: http://www.racerpartswholesale.com/cooler1.htm
Right now in my car I am running Redline 75W140 and have been satisfied, it's a nice medium between gear protection and easy shifting.
Old Oct 18, 2006 | 05:26 PM
  #110
VR4orceCJ's Avatar
Cool
Yes I have to run this particular cooler, but you don't so use the one that is best for your application. In my GVR4 I have a big ole one with an attached fan
Old Oct 18, 2006 | 09:00 PM
  #111
fastevo03's Avatar
I have been using Mobil 1 Gear oil 75W90 tranny and 75W140 for transfer case and Mitsu Diaqueen for rear diff. Mobil1 works fine for the last 13k for many track days.
Old Oct 18, 2006 | 10:30 PM
  #112
marksae's Avatar
FYI, the Mobil1 75W90 gear oil is GL5. Spec for tranny fluid is GL4 oils only. GL5 oils have been reported to be corrosive to brass and copper. Our synchros are made of brass.
Old Oct 19, 2006 | 12:33 AM
  #113
m3charles's Avatar
okay, i'm switching fluids after this event. And then I'll keep my fingers crossed..
Old Oct 21, 2006 | 05:34 AM
  #114
johnr265's Avatar
For those using OEM fluid in the transmission, where are you buying it from? I got the same info from my dealer that they have a 5 gallon drum. He was willing to sell it to me in smaller quantities but I am not sure I trust them as he said they too use the same fluid in the tranny, t/c and diff.
Reason being, I have already changed the diff and T/C using the diaqueen LSD and I put in the BG synchroshift 2 in the tranny and I think the car shifts like crap. I can feel every shift, it sometimes sticks in gear and generally is worse than it was before I changed it from the stock fluid. Anyone else experience this? Granted, I am spoiled because my other car is a turbo miata and that thing shifts like butter but I don't remember having problems with the evo before the bg2.
Thanks.
Old Oct 21, 2006 | 05:57 AM
  #115
x838nwy's Avatar
Seeing that someone else has resurrected this thread, WHAT IS IN THE DIAQUEEN?
I mean, I keep hearing horror stories and actually has a friend experienced at tc dying before my eyes. Now everyone, including myself use the Mitsu oils and apart from the Motul (which imo is still unconfirmed), there is really no alternative.
So, as said, what the heck makes the Disqueen so special? Sure Mistbishi has the stuff made for them by an oil company, so who is it? I just scares me to think that the evo uses an oil unique to it...
Old Oct 21, 2006 | 06:06 AM
  #116
marksae's Avatar
According to the shop manual, the transfer case requires that you use a straight SAE 90 hypoid gear oil. Jon@TRE (gears) stressed how important the hypoid part is because it protects the teeth on the ring and pinion gears.
Old Oct 21, 2006 | 06:15 AM
  #117
x838nwy's Avatar
marksae, thanks dude.
any info on how much that applies to JDM MR Evo's with ACD+S-AYC?
Old Oct 24, 2006 | 09:34 PM
  #118
NDgsx's Avatar
This will apply to your evo as well, hypoid is a designation of way the ring and pinion gears contact each other in the diff, your's are the same.
I have had NO problems with redline heavy weight shockproof in the tc, John Sheperd recomends OEM or redline hw shockproof only also.
Old Oct 24, 2006 | 09:40 PM
  #119
x838nwy's Avatar
^ I understand about the hypoid thing. What I'm concenred with is the AYC and S-AYC difference. I'm not entirely sure if the components such as friction plates and so forth in there require anything special. IIRC there is a physical difference (rather than an electronic one) between the AYC and S-AYC and the different mechanisms prehaps require different oils?
  #120
ashumo's Avatar
2qts of Redline MT90 + 1qt of Redline 70w90 NS for the tranny (5MT), OEM Diaqueen for the TC and rear diff.
