oil overfill, HPDE this weekend...
Old Feb 26, 2007 | 05:38 PM
texrex2002's Avatar
I just checked my oil, and the shop that changed oil last week overfilled.
the oil level is about 5/8" above the upper notch (ie about the same distance above the upper notch as is between the notches).
I don't know enough about the 4G63 to know if that is a problem. On subarus an overfill would cause the crank to "froth" the oil and the pump would cavitate; so overfilling was a big no-no.
what about with evo's?
the car doesn't burn any oil during hard street use, but I suppose it might use some at the track event this weekend.
should I just leave it as is, or drain some?
Thanks!
Old Feb 26, 2007 | 06:16 PM
992gnt's Avatar
Drain it. It's not worth taking a chance on.
Old Feb 26, 2007 | 06:19 PM
Vishnu_Evo8's Avatar
just be safe and drain it a tad till its near the top mark.. why risk it for a couple minutes?
Old Feb 26, 2007 | 06:40 PM
DaWorstPlaya's Avatar
I try to keep the oil level to the max line or I usually slightly overfill the oil during a track day because the oil pools to one side or the other during high G manuvers. The last thing I need is to spin a bearing because of oil starvation. 2-3mm over the max line is what I usually follow.
Old Feb 26, 2007 | 07:22 PM
mayhem's Avatar
Did you measure it while on level ground?
A little over is OK, but I would say 5/8" might be on the borderline. I'd drain a little off. If it's bad for the motor and causes frothing...I don't know, but erring on the side of safety can't hurt.
Old Feb 26, 2007 | 10:00 PM
Ludikraut's Avatar
Drain it until its at the upper notch or at least within 1/16" of it. 5/8" would have me worried.
l8r)
captainalvy
Jul 19, 2016 09:45 AM
mrm95
14
Aug 4, 2013 09:57 PM
Randal
47
Aug 31, 2012 08:23 AM
bestthereis27
34
Jan 23, 2007 02:24 PM
Trbo Dad
14
Dec 14, 2003 02:10 PM
