Proper engine cooling
Old Mar 14, 2011 | 06:42 PM
  #31
sblvro's Avatar
I think I showed you the pull fan I installed(before the crash) it really help the oil temp a lot. but since it was a pulling fan, the right tire without the shield felt warm.
Old Mar 15, 2011 | 07:19 AM
  #32
Balrok's Avatar
Ya I remember seeing that so I knew it was possible.
Old Jul 1, 2011 | 04:41 PM
  #33
Balrok's Avatar
Update since Boom reminded me.
3 events since Install. Water temp STAYS ~ 195 and oil stemp STAYS ~ 235 max, goes down to 190 on a single cool down lap. This is in Florida 90+ outside temp and 130+ track temps. Guys, this really does work. For me it didn't make sense why a fan in the FRONT of the oil cooler would work, but hell yes it does. The only drawback i've seen thus far is the inside of the pass front tire goes up slightly more then all the rest due to the hot air blowing on it as sblrvo said. But there's ways around that.
Old Jul 17, 2011 | 06:17 PM
  #34
EVO8LTW's Avatar
I'm wondering if I could make that 13" fan fit with a Buschur 4" (i.e., 3.8") FMIC? Are there 2 fingers of clearance from the FMIC with the 3.5" one you have? It's a little hard to tell in the picture. Thanks for the tips!
Old Jul 17, 2011 | 08:30 PM
  #35
Balrok's Avatar
Two small fingers yes. You could also put washers/spacers where the intercooler mounts to the rad supports if it was close.
Old Oct 20, 2015 | 06:48 PM
  #36
Nimpoc's Avatar
Probably have a couple more events on the car by now... Are you still running the stock oil cooler and SPAL fan with nice low temps?
I'm in the market for a bigger cooler, but a $60 fan + relay would be way cheaper!
Old Oct 20, 2015 | 07:43 PM
  #37
sblvro's Avatar
Didn't know you're still into racing! Did you sell your 9?
Old Oct 22, 2015 | 01:06 PM
  #38
Balrok's Avatar
Yep still going strong, 2015 was sh*t on by the house project but look for more in 16.
Old Oct 23, 2015 | 05:36 AM
  #39
Ralliart004's Avatar
Veteran: Air Force
This is really good info guys thank you for the updates
Jaraxle
Mitsubishi TC-SST Discussion
16
Feb 10, 2018 06:09 PM
Boostin_hard
14
May 27, 2017 06:56 PM
RallySport9
Apr 13, 2017 03:06 PM
TheBoz
Oct 18, 2016 03:47 AM
doncarbone
42
May 1, 2016 09:45 AM
