Perfect Track Wheels Thread
I love the RPF1's. I've used them on a couple different track cars. Hard to beat for the price, quality and weight. Cheap enough to buy a couple sets if you have multiple sets of tires. I always need to bring at least two, if not three sets of tires to the track with me...wets, practice, and race. No way I can afford two or three sets of CCW's or Volks.
From: Why do they always call the Evo the Dark Side?
So I'm pondering going to 17x9.5's for STU next year. Is there anything that meets this criteria?
* 17x9.5
* Not heavy
* Not violently expensive
* Can be run on all 4 corners (spacers OK, I already have the ARP studs)
I saw in Doug's thread that he's using RPF1s for this but using different ones F/R...
thanks!
* 17x9.5
* Not heavy
thanks!
NT03+M
18x9.5
2xx/35/18
No spacers
Rolled rear fenders and cut front fenders
What offset would be ideal to get the widest size possible? I'm having a hard time figuring out which offset would work best for me. I want to get some track wheels and tires to replace my stock BBS wheels and Z1 Star Specs.
18x9.5
2xx/35/18
No spacers
NT03+M
18x9.5
2xx/35/18
No spacers
18x9.5
2xx/35/18
No spacers
* 17x9.5
* Not heavy
thanks!
* 17x9.5
* Not heavy
thanks!
NT03+M
18x9.5
2xx/35/18
No spacers
18x9.5
2xx/35/18
No spacers
My track setup is actually an 18x9.5 +27 NT03 w/ 285/30/18s. I didn't pull my rears, but I did have to raise the car to minimize rubbing. This is with 16kg rear springs though...
On an 18x9.5 a +35 offset is a safe offset. You can fit 255-285 on them +22 offsets are more aggressive. 255 - 265(might be tight) +15's are very very aggressive. 234-245 and expect some rubbing and other stuff
I run the Enkei RC-T4 18x9.5 ET30 with 265 35 18 or 275 35 18 at the track. No spacers required, no rubbing, no fender modifications needed. Actually selling in classified right now. Don't go below 9.0" in width or 255's. The larger sizes can fit if you find the right offset and spoke design with proper back set dimensions.
R/T Ernie, Factory Body but rolled and or cut fenders right? Did you do the work or can you recommend a shop?
I rolled my rears but am not completely happy, there's a seam in the rear that still gets in the way.
Regarding your rims, they look like RPF1 but what offset?
