Perfect Track Wheels Thread
Old Aug 22, 2011 | 05:02 PM
  #196
SWOLN's Avatar
Year/Make/Model: 2006 GG
Wheels: 18X9.5 +35 TC105N 15mm Front Spacer
Tires: R888 275/35/18
Suspension: Ohlins Flags
Alignment: -3.0f/-1.6r 1/16th toe-out front & 0 toe rear
Fenders Rolled or Cut: Minor rolling rear
Other Body modifications: Trimmed the inner pinch weld in the drivers' front wheel well,
extended studs in front.
Advice: Take your time, don't rush, and be patient.
I also want to thank R/TErnie, and Evolutionary for all of the tips, and many questions they answered for me along the way.
Galaxy S pics attached...
Old Aug 30, 2011 | 06:43 PM
  #197
EvoJoeRacing's Avatar
Anyone know the weight of the Works Emotion XD-9 18x10 +38?
Old Sep 2, 2011 | 11:16 AM
  #198
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Do you have any issues with rubbing up front under hard braking?
Google says 24lbs. I would confirm though.
Old Sep 2, 2011 | 12:08 PM
  #199
SWOLN's Avatar
The only rubbing I'm getting is from the side skirt, in the rear of the front wheel well.
Old Oct 5, 2011 | 12:39 PM
  #200
projectmarzen's Avatar
did you have to run the 15mm spacer for clearance? could a smaller one be used in the front? (or none at all)
Old Oct 5, 2011 | 01:09 PM
  #201
SWOLN's Avatar
I needed the 15mm spacer for clearance. I thought the the 6 inch spring I used would have let me run no spacer at all. Unfortunately, I was wrong. 15 mm is the minimum I would run.
Old Oct 11, 2011 | 03:27 PM
  #202
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Anyone have any idea why the 17" NT03s are heavier than the 18" of the same width?
Old Oct 11, 2011 | 04:24 PM
  #203
R/TErnie's Avatar
spoke design?
EVOlutionary
Mar 29, 2013 04:13 PM
EVOlutionary
For Sale - Wheels / Tires
19
Nov 12, 2012 08:49 PM
EVOlutionary
Nov 4, 2012 08:38 PM
EVOlutionary
23
Mar 29, 2011 03:18 PM
EVOlutionary
Aug 7, 2008 10:06 AM
