STU ECU questions
From: Why do they always call the Evo the Dark Side?
My inference from that was that the smaller the hole between the wastegate outlet area and the rest of the O2 housing, the more creep you'd get. So I would think you would want kind of an eBay housing, but with an even smaller hole. But this is complete speculation on my part. I am not a flow analysis thermo-mathingy.
Even easier than a new O2 housing is crank the preload on the wastegate actuator. Changes to the boost cut (not boost map) will need to be made to make it legal. We have done some 330+whp STU cars, if I remember my classes right. I know we couldnt touch the boost map but could tune everything else in the ECU.
I am not sure that changing the boost cut is legal:
14.10.F
F. The engine management system parameters and operation may be
modifed only via the methods listed below. These allowances also
apply to forced induction cars, except that no changes to standard
boost levels, intercoolers, or boost controls are permitted. Boost
changes indirectly resulting from allowed modifcations are permis-
sible, but directly altering or modifying the boost or turbo controls,
either mechanically or electronically, is strictly prohibited.
330whp sounds more like Street Prepared, doesn't it? If I understand correctly, you can run a BSP Evo on race gas and advance the heck out of the ignition.
And, Street Prepared cars are allowed to change the intercooler and related pipes.
They lost the "Street" out of Street Prepared decades ago. I hope that doesn't happen to Street Touring.
Last edited by BluEvo210; Jan 19, 2012 at 12:41 PM. Reason: Added part about intercooler
Anyone have any other interpretation here?
I've noticed that most of the STU folks have the Megan/eBay O2 housing. And I've also noticed that people on the rest of the forums say that they get boost creep from that housing, whereas they don't get it with the bigger O2 housings like the Invidia.
But the OP has an Evo X. I don't know if anyone makes a poorly-constructed O2 housing for it yet.
I have one of these:
...Which is why, in theory, I can restrict the wastegate outlet without affecting the main exhaust flow.
Obstruction in the pipe, smaller pipe in the wastegate segment, etc. would all accomplish the same thing. The problem is that it's going to require some trial-and-error to find the sweet spot for your setup. If you obstruct it too much (an easy line to cross) then you're going to run into serious boost creep problems if you ever build boost in higher gears. Obstruct it too little and you probably won't notice much at all.
...I'd steer clear of the obstructed wastegate trick unless you're willing to go through several cycles of fabrication, assembly, testing, disassembly, and tweaking. The additional boost isn't going to make that much of a difference at an AutoX.
"Serious boost creep" = "engine go boom"?
It seems like it would be SO easy to insert a washer in the wastegate pipe, but I can't afford to damage my engine.
Last edited by BluEvo210; Jan 19, 2012 at 09:18 AM. Reason: Trial and error in photo posting
Oh, well... It doesn't matter in my case, since there isn't a Sunoco or anyone with E85 in this part of Florida.
EDIT: One web site says there's E85 available 68 miles away in Enterprise, AL. I can't find their price, though.
Sorry just noticed you asking about setting the outlet size on the wastegate. Once again changing the preload is illegal but very hard to prove.
When i mentioned changing the size of the outlet hole i believe most of the competitive guys are closing the hole down to 1/2 inch or less but most are running E85 as well to compensate for the crazy boost spike they are seeing.
To make this work on your car will cost you considerable trial and error, as someone already mentioned it will take a lot of testing to find the ''sweet spot'' on your setup and custom fab work as well to make it optimal, this is not the best setup for a DD. But if you spend the time on it makes for a sick power curve for an STU car.
So, to get any more gains out of engine tuning, it sounds like I should focus on the software. I think the shop might have left 10hp or so on the table.
Last edited by BluEvo210; Jan 19, 2012 at 11:35 AM. Reason: Added line about software
Back when I was setting up for STU in early 2010, my tuner (Bryan, then @ GST) joked with the idea of doing e85 on a stock fuel setup, but then didn't want to run the risk of running out of fuel and harming the motor.
I'm running e85 now, but now it's an SM car.
