STU ECU questions
Old Apr 5, 2016 | 02:10 PM
  #106
RJones's Avatar
Now if you really wanna go broke, SM is the place to be... Just ask my Mitsubishi GT3 sitting in the garage...
Old Apr 5, 2016 | 03:26 PM
  #107
Dallas J's Avatar
Veteran: Army
Quit blowing motors, I'm only ~50k into my car (with car) :P
Old Apr 5, 2016 | 03:29 PM
  #108
RJones's Avatar
My newest motor build is costing roughly half that , but it's my fault as I went *slightly* overboard when spec'ing it out. On the bright side, if I ever want to slap on a 9180 and make 900whp I can without making any other changes...
Old Apr 5, 2016 | 03:34 PM
  #109
Dallas J's Avatar
Veteran: Army
I could have 4 motors for that price... eek.
I plan for my motor to last 3 years before pulling it to refresh it. So we keep revs to 7500 unless at a tour/pro. I also only up the boost when I need it.
Old Apr 5, 2016 | 03:53 PM
  #110
RJones's Avatar
Well I'm also having a high end shop build it and do all the labor, so if I'd done it myself it would've been a whole lot cheaper.
Old Apr 5, 2016 | 03:55 PM
  #111
Construct's Avatar
Meanwhile, I still daily drive my STU Evo on the original motor.
I'm sure that won't last forever, but I'll enjoy it while it lasts.
Old Apr 5, 2016 | 04:11 PM
  #112
RJones's Avatar
Yeah... I constantly wish that I'd stayed in STU instead of starting an SM build 5 years ago.
Old Apr 5, 2016 | 04:20 PM
  #113
Dallas J's Avatar
Veteran: Army
Same here, sometimes wish I could go backwards to STU. I think if I ever move on from SMevo I'll move to the new STP class and work on my mullet.
Old Apr 5, 2016 | 04:28 PM
  #114
RJones's Avatar
I'm really enjoying life in FS right now. The V8 S65 makes good noises and I get to practice weaving in and out of paddock traffic without using my blinker.
Back on topic: Someone should do some hole saw/washer testing back to back and post results...
Old Apr 5, 2016 | 04:33 PM
  #115
Construct's Avatar
Does anyone have any idea where to start with in terms of restrictor opening cross-section?
Old Apr 29, 2016 | 12:03 PM
  #116
BluEvo210's Avatar
I'd start small, of course.
And, instead of the holesaw it occurred to me that one might use a threaded bung with a large bolt screwed into it.
I don't know how you'd seal that any more than you'd seal the holesaw setup.
I'd also want it to be accessible while the car is on a dyno, and that would be tricky.
However you do it, I'd start with the minimum restriction as the baseline, and screw the bolt a couple of turns farther in with each dyno run until you get some reading you decide is scary.
After you leave the bolt alone for a while, the exhaust might seal the threads for you, by melting them together.
Old Apr 29, 2016 | 01:35 PM
  #117
LetsGetThisDone's Avatar
What if you set it up to where you can thread a bolt on that the wastegate flapper hits and limits how far the flapper opens? Use a jam nut and it'll basically be fully adjustable..
Old May 2, 2016 | 09:21 AM
  #118
Construct's Avatar
That's what I suggested one page ago:
The MAP O2 eliminator recirculated downpipe has a fully separate piece of tubing on the wastegate side that extends for several inches. I always thought it would be fun to weld an O2 sensor bung in to the wastegate tube and then insert a long M18 bolt in the tube to impede the wastegate exhaust flow. A long bolt with a locking nut could be used to adjust the restriction and the bolt could be swapped for a normal plug when you wanted to go back to normal functionality. I don't know if an M18 bolt would even be enough of a restriction, but it would certainly be easier to tune and adjust than the washer or holesaw method.
As for this:
That's technically illegal because the wastegate flapper is considered part of the boost control system. You'd have a hard time convincing anyone that limiting the wastegate range of motion doesn't count as a modification to the boost control system. Meanwhile, boost changes secondary to exhaust changes are explicitly allowed:
Relevant rules section:
no changes to standard boost levels, intercoolers, or boost controls are
permitted. Boost changes indirectly resulting from allowed modifications
are permissible but directly altering or modifying the boost or turbo controls,
either mechanically or electronically, is strictly prohibited.
Old May 2, 2016 | 10:10 AM
  #119
If that's how the rule is spelled out, I would think putting a bolt in the divorced section of the MAP down pipe could easily be construed as not legal. I'm sure the rules state that is they don't say "this is allowed" then you are to assume that is not allowed. And I'm sure there is nothing in the rules saying you are allowed to restrict the exhaust flow down stream of the wastegate by threading a bolt into the DP...lol
Old May 2, 2016 | 11:52 AM
  #120
RJones's Avatar
Exhaust is unlimited save for the 100 cell cat requirement and the fact that it has to exit behind the driver. The divorced section of the downpipe is part of the exhaust system and modifying it with a bolt would totally be a legal exhaust modification. The rules say you're prohibited from modifying the boost control system, but indirect changes to boost due to legal modifications are permitted.
