Traction on or Traction off?
Old Mar 27, 2012 | 07:07 PM
ajithsilva's Avatar
Hey guys,
I will be participating in an AutoX for the first time this weekend. Do you think I should turn my traction control off for the event to achieve better performance?
Thank you,
AJ-
Old Mar 27, 2012 | 08:40 PM
GTisRule's Avatar
Huh? My traction control is my right foot... Must be a X thing
Old Mar 28, 2012 | 02:13 AM
sujinX's Avatar
no traction control here on my 8 ??? only X's have it?
if i were u and its your first time ever, then keep it on. but its better off. imo
Old Mar 28, 2012 | 02:22 AM
MR. EVO MR's Avatar
Try it first with traction on, feel the ride, get comfortable then switch it off and see feel the difference.
Don't forget more air in tires too!
GL
Old Mar 28, 2012 | 05:01 AM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Which event is it? If you see someone in a silver MR, say hi!
Old Mar 28, 2012 | 11:39 AM
dek0026's Avatar
turn the asc off for sure. just one quick push of the button. you don't want traction control on for autox. one little slip of a tire and the ecu will shut you down.
you can play with turning the awc off from run to run by holding it down for 3 seconds until you hear a beep. i found that in autox i was much faster with everything off. you really shouldn't have to worry about electronic nannies for autox.
Old Mar 28, 2012 | 12:43 PM
ajithsilva's Avatar
April 1 @ FedEx, in MD.
Old Mar 28, 2012 | 12:46 PM
ajithsilva's Avatar
Thanks to everyone for their advise. I thought it should be off but I was not sure since I'm an amateur! =)
Old Mar 28, 2012 | 01:54 PM
an2ny's Avatar
I will be there, but not driving the Evo.
Yes, TC should be off the AWC you can try it on or off. It is an AutoX worse case you will hit a cone.
Old Mar 28, 2012 | 04:36 PM
Butt Dyno's Avatar
Awesome... I'll be there in STU.
ryan010
Sep 27, 2016 10:25 PM
Lanart2011
Mar 22, 2016 11:50 AM
AGinHD
Sep 4, 2012 11:23 AM
laksman91
Feb 23, 2009 11:31 AM
DoHBoY
May 30, 2007 10:13 AM
