oil coolers - location and efficiency
Old Jul 11, 2012 | 10:00 AM
killerpenguin21's Avatar
Originally Posted by honda-guy
here's my oil relocated to the front
see the top of the intercooler from the center mounting tab over to the passenger side end tank is begging for a nice wide cooler to me. you could fit something almost a foot wide there i think, so the oil would have a nice long distance to be pumped across the cooling surface. That would not requrie moving any fans or anything, and i believe it would give you room to run the lines (although i havent looked).
the question is, why has no one done it?
Originally Posted by boomn29
Yeah, the option in the front middle is about the best I've seen here.
We've been over this a few times in different threads. Do some searching (in this forum) and you should be able to pull them up. The problem is there's nothing aftermarket that's much bigger relative to the cost of them. imo it needs to be in more direct air like the above pics.
your the main person i see posting hard data about oil temps. how come you havent upgraded yet out of curiosity?
ill do some more searching. i saw some mention, but most of the "front mounts" were setups like honda-guys.
Old Jul 11, 2012 | 10:08 AM
Kidloco51's Avatar
^ I am gonna cut my intercooler tab off in the middle and relocate. The oil cooler I have is about 14" long so I need the room.
Old Jul 11, 2012 | 10:29 AM
do you happen to know the measurement from end tank weld to the tab? i run an ets 3.5, im assuming most re the same, but just for a reference point anyway.
im very interested to see what you do for mounting.
Old Jul 11, 2012 | 01:36 PM
just thinking out loud hear...but which direction does heat flow in the motor?
by that i mean:
does hot water heat the oil?
does hot oil heat the water?
on one hand id think oil would have a better heat capacity, but then the water is pressurized...
Old Jul 11, 2012 | 11:27 PM
codgi's Avatar
I went with the MAP oil cooler as well and have an oil temp gauge. Not tracking again until next year so won't have good data for you on that until then
Old Jul 12, 2012 | 04:00 AM
apex electric's Avatar
I talked with Reese Millens engineer years ago about high evo oil temperature. He told me that he took the gauge out of their race car because it was pointless to worry the driver.. These cars will run all day in California sun and heat with no ill effects. Don't woory about it, the stock cooler is all you need.
Old Jul 12, 2012 | 09:54 AM
thats interesting and all, but i also bet they arent running convention off the shelf oils and internals...and are also probably rebuilding motors every event. even with a high end oil like amsoil, some data i have come across shows breakdown starting at around 260 degrees versus 240-250 or even lower on some ots oils. and some cars like the 929 evo are documenting steady temps above 260. much higher and you get to start worrying about bearings.
i have a hard time believing that the stock is adequate for more than street driving.
Old Jul 12, 2012 | 11:36 AM
justboosted02's Avatar
FYI guys, those pretty Setrab units are just rebadged Derale. i got mine from jegs for much cheaper than a setrab
Old Jul 12, 2012 | 03:48 PM
Kidloco51's Avatar
How big of AN lines are you guys running? Im building -12an lines
Old Jul 12, 2012 | 03:55 PM
honda-guy's Avatar
mine is -8
Old Jul 12, 2012 | 05:55 PM
My 350 whp stock motor runs race events with Mobil 1 and I have never had a bearing failure. We did put a oil pressure light in 2 years ago and it would turn on in some right hand corners like the toe of the boot at Watkins Glen pulling 1.7 g's Charlie North extended the oil pan and pick up and with over 7 quarts the pressure light does not turn on any more. Still using the stock oil cooler. The car has extensive air sealing around the front bumper to manage flow and a open screen in the wheel well to exit air from the oil cooler.
Old Jul 12, 2012 | 06:05 PM
so is your cooler not getting direct air flow? and what are you running radiator wise?
Old Jul 12, 2012 | 06:27 PM
A stock 8 bumper with simple plastic fillers to manage air flow. I use the stock underhood sealers and white plastic to seal the front bumper and motor bay. The oil cooler has the stock opening. The other is covered. My simple air/intake box pulls air from the radiator opening.
Old Jul 12, 2012 | 06:53 PM
Robevo RS's Avatar
Mine is relocated above the crash beam over the IC. I am not sure how much you will see, but i think it is still visible a bit in this picture. You can find it at the lleft from the Mitsubishi symbole. It is not a factory cooler and has an upgraded lines too. Working perfect there , and far away from any danger zone down there
Old Jul 12, 2012 | 07:28 PM
^^^the evo x's are what spawned the idea in my head...you guys are able to easily mount it to the crash beam tho. i wish i could think of a clean effective way to mount it directly to the intercooler, but my welding sucks.
my other thought is to run one vertically on the drivers side between the condenser and the intercooler (kidloco has his tranny cooler there), but that would lead to some very long lines.
