oil coolers - location and efficiency
Old Jun 1, 2013 | 12:39 PM
  #91
Balrok's Avatar
Originally Posted by j255c
Bump
Unless you have a special turbo that doesn't rely on the engine's oil supply then yes you'll need to cool the oil external to the engine/turbo. Spending 5k on an engine and not putting the basics back in is a waste of time and money.
Old Jun 1, 2013 | 08:36 PM
  #92
j255c's Avatar
This forum has a lot of misinformation as well, many people say its fine to run an oil delete if you just do occasional pulls on the street.
Old Jun 2, 2013 | 07:32 PM
  #93
Balrok's Avatar
It's common sense. That's like saying you can run 30psi all day on stock turbo and 91 octane, could you do it ya, but it's retarded advising on that because NOBODY does just "occasional" pulls, and they'll just end up in the shop all the time.
Old Jun 2, 2013 | 10:01 PM
  #94
j255c's Avatar
https://www.evolutionm.net/forums/ev...il-cooler.html
Dont understand, Buschur said its ok.
That being said I'll be installing one once I break in the motor and its tune time.
Old Jun 3, 2013 | 05:36 AM
  #95
chu's Avatar
chu
It's probably fine for street driving and drag racing. I didn't use an oil cooler for 1000 miles during my break-in. However, this is the motorsport section. These guys spend 25-30 mins, sometimes more, beating on the car on a track setting. Its not 10 secs down the drag strip and then sit and wait for the next two hours. Our needs for cooling capacity is a lot higher than the a drag car or street car.
Old Jun 3, 2013 | 05:07 PM
  #96
Pure EvoIX's Avatar
+1 what he said.
Old Jun 3, 2013 | 07:21 PM
  #97
jerdeitzel's Avatar
You must not run TT then. Its about 3 laps then done! I ran a very strenuous hillclimb without an oil cooler after an accident. Not what i would want to do all the time but it's not the end of the world. The rally guys have been known to run without them too if needed.
Old Jun 5, 2013 | 08:49 AM
  #98
chu's Avatar
chu
TT, Hillclimb, or rally, it still isn't 10 secs or less. I think its necessary to have one.
Old Jun 5, 2013 | 09:00 AM
  #99
DaveK's Avatar
I ran a few laps at GTA last year without one after one of the cooler lines got burned thru by the exhaust. Not ideal and the car is getting fresh oil before it hits the track simply because temps were probably high.
FWIW, rally guys don't make much HP due to the restrictors, but for those that do run anti-lag, temps on everything can easily be elevated.
Dave
Old Jun 5, 2013 | 09:19 AM
  #100
jerdeitzel's Avatar
Sorry, i was by no means saying that you shouldn't use one. I was just stating that its something that i wouldn't let end my weekend if i didn't have one. A trans cooler would be a good idea also.
Old Jun 6, 2013 | 03:17 PM
  #101
211Ratsbud's Avatar
I have no condenser, so is the next best place on an ix hanging from the rad support in front of the radiator above the inter cooler? I make 420~ hp and my koyo rad isn't being exercised very hard (from what I see others push for hp.) I only autocross a couple times a month and switched to a 5w-40 for summer.
I want to take my oe cooler off the danger area cause I had an off course and hit a generator last year. The retarded cart drivers requested that a sump be installed at an adjacent water hole to stop runoff . ( stupid cause they never work the course )
killerpenguin21
Jun 23, 2015 12:22 PM
mishimoto
Mar 28, 2014 01:28 PM
Pure EvoIX
Apr 21, 2013 04:40 PM
cal1mr
Oct 7, 2009 02:26 PM
EVOXTIMES
Mar 26, 2009 09:55 AM
