Looking to improve handling
Old Jun 16, 2014 | 06:35 PM
  #76
cfdfireman1's Avatar
OH. you mean a
Originally Posted by EVOizmm
Roll centre/bump steer - correction kit
Old Jul 11, 2014 | 01:41 PM
  #77
ViciousLSD's Avatar
The ONLY time my car felt right and pretty good at autox was right after the diff fix. I only formed this conclusion recently - because I have lost the setup - meaning the car understeers now, after the winter. I always thought it was my tires that got too old or got affected by the winter cold. new Z2 tires didnt help. I corded brand new A6s(front) in 10 60sec runs . I used the autox events in the last 6mos to figure it out... ride height, swaybar stiffness, shock settings - nothing from my notes were working. my last hope is changing out the rear lsd oil and hope it starts grabbing again. I havent done that so I'll report back later
That was it. New lsd oil put me back on top at that last autox event
Old Jul 11, 2014 | 01:48 PM
  #78
kaj's Avatar
kaj
nice, easy fix! how much driving had you done on the old fluid to make it so ineffective??
i keep recommending the rear diff fix but nobody wants to hear about it. they are stuck on buying larger rear sway bars. to each their own, i guess.
Old Jul 12, 2014 | 04:41 AM
  #79
mouseIX's Avatar
Rear diff and ACD tune. Magic!
Old Jul 12, 2014 | 05:27 PM
  #80
kyoo's Avatar
Originally Posted by Iowa999
While I agree that you won't get much downforce from the undertray, one of its main purposes is to create the partial vacuum so that the air from the NACA duct goes down across the turbo and out the bottom.
edit: nevermind; we seem to be talking about something older than an X, given the bit about restacking the rear diff plates
while on this - i've got a carbing aluminum undertray on my evo, frankly doesn't seem that great heat-wise, I could only imagine it does better keeping heat in than dipsersing it like the OEM plastic one would - any thoughts on this from anyone?
Old Jul 12, 2014 | 07:18 PM
  #81
golgo13's Avatar
EvoM Community Team
Veteran: Navy
IIRC just having an undertray creates a pressure differential that draws the heat up and out the louvers in the hood.
Old Jul 13, 2014 | 11:11 PM
  #82
ViciousLSD's Avatar
about 1500mi. At the beginning of the year I have been drifting my old tires. That probably used up the effectiveness of the lsd oil. It just fell flat on its face as soon as it got warmer and got new ZIIs. It sucks it took me this long to figure it out
Old Jul 14, 2014 | 07:44 AM
  #83
kaj's Avatar
kaj
Wow. But good to know. Thank you.
Old Jul 14, 2014 | 02:10 PM
  #84
kyoo's Avatar
icic.. sounds like that's regardless of the undetray. i guess i'll keep it.
to note, boomn929 in his hay days in TTB/A had some heating issues with his brakes + no undertray, and swapped fluid to amsoil brake fluid and plastic undertray and no more overheating brakes. all the things i just said could be totally flip flopped though, i don't remember.
Old Jul 14, 2014 | 02:14 PM
  #85
heel2toe's Avatar
What kind of oil are you using? What happened such that it no longer allowed lockup?
Could it be that the same lockup was still present however with your new grippier (not sure that is a word) tires the backend no longer had the ability to break loose?
Old Jul 14, 2014 | 02:28 PM
  #86
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You can't create a vacuum with a hole in the bag.
I feel like there is some data missing here.
All things being equal, I think the Japanese engineers at Mitsubishi put these parts on the car for a reason.
Old Jul 18, 2014 | 09:50 AM
  #87
ViciousLSD's Avatar
Well youre right, definitely all these variables factor in in basically getting the front grip > rear grip AWD story. I did have new tires when I got the restacking done and that was the best performance i got out of my car.
Probably an unconventional choice with LSD oil... I switched from redline to Lucas (yes that one) because i wanted less clunky diff and the outcome was what I expected (great). seeing the rear lsd is similar to my toyota lsds (cusco/kaaz) and I had good results with lucas oil in them I just had to try and I didnt look back. Now I have some time to do some back to back testing with redline and lucas (the latter is cheaper to flush of course lol)
Old Jul 18, 2014 | 10:49 AM
  #88
kaj's Avatar
kaj
Let us know how that goes. I've never used anything other than OEM (as per advice of Jack's Transmission), so I'm curious of how other stuff works.
josh_evo9
Jun 17, 2016 08:20 PM
Jonno99
Jul 12, 2015 02:47 AM
TK40
Mar 11, 2012 10:15 AM
Joey B
52
Mar 1, 2011 03:17 PM
Jedi@MaxumTec
47
Mar 9, 2010 01:32 PM
