Professional Awesome Racing Time Attack Roll Cage
Old Feb 9, 2015, 07:02 AM
rawkus's Avatar
Hope this can give you guys a good starting point on cage design. This is what we felt was the best option for us. Everything is over on MotoIQ. I'll answer any questions you may have here as well. Thanks!
Dan
http://www.motoiq.com/MagazineArticl...in-Detail.aspx
Old Feb 9, 2015, 01:17 PM
jerdeitzel's Avatar
. Why not put this in the thread showing roll cages that was just started?
Old Feb 10, 2015, 05:24 AM
honda-guy's Avatar
nice, thanks for sharing
Old Feb 10, 2015, 06:52 PM
Butt Dyno's Avatar
Location: Why do they always call the Evo the Dark Side?
Clearly those are neither Professional nor Awesome
Old Feb 10, 2015, 06:53 PM
mouseIX's Avatar
Whoa. I'm pretty awesome
Old Feb 10, 2015, 08:35 PM
flyingscot's Avatar
thanks Daniel
Old Feb 11, 2015, 06:04 AM
rawkus's Avatar
I debated it... but then would I just post pictures or would I post everything I wrote too? I figured this route would be more simple.
Dan
Old Feb 11, 2015, 06:21 AM
EVOizmm's Avatar
What's another thread.
I like the write-ups Dan. very informative and fun to read.
Old Feb 13, 2015, 03:44 PM
mkcolgan's Avatar
Great article.
-Mike
Old Feb 13, 2015, 05:24 PM
deylag's Avatar
I read your article intently because I also have a chassis that I want to prep for the track.
I also want to take in the same direction that you guys did. I have come across a stripped chassis that was stripped due to theft. I plan to have it seam welded and caged.
I know you guys pointed out that the better way to prep the chassis was to dip it and then coat it. However, I am a newb when it comes to prepping a car chassis for the track.
I will try to research local companies in my area that could dip my chassis, coat it, seam weld it and cage it. Any additional advice?
Old Feb 15, 2015, 07:42 PM
rawkus's Avatar
The best advice I'd say is to make sure you cut ALL the metal you don't want, then dip, then do the cage and seam welding... then have it coated. That's the best way to go about it and the way we should have done it. Also, I've heard that alkaline dipping is safer for than acid dipping, but that's just what I've heard, I haven't had personal experience with either.
Dan
rawkus
Jun 12, 2017 10:44 AM
rawkus
Apr 14, 2017 09:22 AM
TxFAkuma
Feb 28, 2017 07:41 AM
rawkus
Apr 13, 2010 08:16 AM
rawkus
Apr 6, 2010 06:41 PM
Quick Reply: Professional Awesome Racing Time Attack Roll Cage
