Measuring Braking Temps
Old Sep 14, 2016 | 10:32 AM
  #61
kyoo's Avatar
The Ti shims did not create an issue with pad temp for me. They simply helped it take longer for the brake pedal to get soft due to the fluid getting hot.
interesting. oddly enough, on stock pads, rotors, etc., my caliper was still RED after FOUR 20 minute track sessions at Autobahn S.
Redid all the brakes, rotors, pads, fluids, and after ONE 15 minute session and ONE 10 minute light session on the same track, they were the infamous brown color.
Theoretically, the opposite should have happened, no? I had Ti shims the second time, with much, much less time on the track. For whatever reason, both the calipers and the rotors got way hotter this go around than last time. No idea why.
Old Sep 14, 2016 | 10:54 AM
  #62
LetsGetThisDone's Avatar
Idk. My calipers were brown after their first session with ST43's...lol
Old Sep 14, 2016 | 11:04 AM
  #63
heel2toe's Avatar
Yeah but you also had different pads on the car. Didnt you lose brakes the first go around? Im guessing your S/S pads were able to handle the heat better before giving up relative to your first go around...what pads did you have on when the calipers stayed red?
Old Sep 14, 2016 | 11:12 AM
  #64
kyoo's Avatar
stock pads - and no, the s/s pads did not hold up better - or at least, longer. the STOCK pads actually made it through 3 sessions without fade - fade only came when I destroyed the pad material itself.
that said, it's obvious for whatever reason, the new set up of DBA rotors and s/s pads got way, way hotter. ambient temps were actually 15-20 degrees cooler this last go around too... why?
Old Sep 14, 2016 | 11:21 AM
  #65
Balrok's Avatar
Solar flares.
Old Sep 14, 2016 | 11:28 AM
  #66
heel2toe's Avatar
Ahh right stock pads. Well that makes sense then since the stock pads are rumored to be the DS2500's and the S/S is very similar...
So same track I cant see ambient temps mattering much TBH and in your case the temps were cooler so thats to your benefit. Maybe you stepped up your game instead of dinkin around on your typical Sunday stroll?
Or maybe the Ti shims do keep the heat in the caliper in which case is what it is better there than your fluid. But just means you need a better(track oriented) pad which we all knew all along.
Old Sep 14, 2016 | 11:35 AM
  #67
kyoo's Avatar
right, but just strange how different the temps were. obviously no way of measuring, but it must have been a significant difference. ti shims keep the heat in the pad/caliper, but I don't know how much of that can be attributed to it. also not sure what temp & duration the brembos change color at..
Old Sep 14, 2016 | 11:39 AM
  #68
Maybe you're just faster since it was your second time out...
Old Sep 14, 2016 | 11:55 AM
  #69
heel2toe's Avatar
Thats what I said...went from really slow to just slow
Old Sep 14, 2016 | 12:00 PM
  #70
kyoo's Avatar
took it fairly easy the first session out, which is when everything happened. actually I have a different theory - higher friction on the new pads compared to the old ones, = much higher heat, even in that short time. does that theory hold any water?
but remember when you got beat by those miatas?
Old Sep 14, 2016 | 12:03 PM
  #71
Heat comes from slowing the car down with the brakes, converting kinetic energy into thermal energy. The more energy conversion going on (slowing down at a faster rate, or from high speeds), the more heat they make. The level of friction they generate doesn't necessarily correlate with how much heat they make.
Old Sep 14, 2016 | 12:05 PM
  #72
kyoo's Avatar
well there goes that. I was braking at the same markers this go around as well, so I wasn't shortening distance or anything..
Old Sep 14, 2016 | 12:12 PM
  #73
heel2toe's Avatar
Lol it was a fast Miata, I swear!
So that's an interesting point. If the pads can generate more friction yes they will generate more heat but assuming the tires have enough grip it translates to the car slowing down quicker. The quicker you get off the brakes the less heat they will generate. So Im not sure it can be associated with that.
However, I suppose if they have a higher μ and youre taking advantage of that then the temps could spike for that short period.
So thinking out loud here...what is harder on brakes? Braking late and hard or braking sooner and slower i.e longer braking period but less aggressive? I always brake late and hard because I think if Im braking slowly then thats precious time that could be better spent accelerating. Of course braking early has its advantages but I guess its all irreverent now that I think about it and type this. Regardless if you brake early or late if the force is the same then the heat generated is the same. So the real question is does a longer braking period generate more heat vs a short hard brake?
Old Sep 14, 2016 | 03:36 PM
  #74
rawkus's Avatar
We run our own stainless steel pistons we designed along with titanium shims and never have brake fluid boiling issues anymore. We run Castrol SRF brake fluid. This is all without brake ducts as well.
Dan
Old Sep 14, 2016 | 04:19 PM
  #75
Dan
Would those happen to be available to the public?
