Old Nov 9, 2020 | 11:06 AM
  #2356
Balrok's Avatar
I'd let map know, cause the fake on on the video with the thin wire and the black connector is exactly as MAP has it in their pics. However that bottom still doesn't add up without the "new design" compare it to.
Old Nov 9, 2020 | 11:15 AM
  #2357
EVO8LTW's Avatar
I did write to MAP last night. Still awaiting a response.
Old Nov 9, 2020 | 11:21 AM
  #2358
EVO8LTW's Avatar
Old Nov 9, 2020 | 11:29 AM
  #2359
EVO8LTW's Avatar
Originally Posted by razorlab
Radium always has legit pumps. I only ever order from them.
Just emailed Radium. They don't sell pumps alone and they won't comment on what the pumps look like that they package with their other products.
Old Nov 9, 2020 | 11:31 AM
  #2360
kaj's Avatar
kaj
You DO NOT lubricate spherical bearings with anything. They have a self lubricating liner. That is all. End of discussion.
Okay, sorry. Dang
Old Nov 9, 2020 | 11:48 AM
  #2361
Balrok's Avatar
Does it have the QR code that works?
Old Nov 9, 2020 | 11:53 AM
  #2362
EVO8LTW's Avatar
No, but that's not a prerequisite of a legit Walbro pump. See attached.
EDIT: If you're wondering if this notice is a fake, it was disseminated by IRPerformance as being from Walbro.
Old Nov 9, 2020 | 12:19 PM
  #2363
kyoo's Avatar
has anyone ever had a titanium exhaust tig welded?
ticon pretty much has everything i need, but i've got no idea how much it would cost to weld it all together. the pipe to resonator to more pipe isn't an issue, but the bends required to get the back muffler straight could be a good amount of work
https://www.ticonindustries.com/coll.../oval-mufflers
Old Nov 9, 2020 | 12:43 PM
  #2364
EVO8LTW's Avatar
Okay, I put in a call to Ti Automotive in Michigan and they just returned my call. The pump is legit. They changed this part of the pump design about a year ago after a change in supplier for that part. Internally, they are the same. Phew. Glad to have some certainty on this.
Old Nov 9, 2020 | 12:52 PM
  #2365
LetsGetThisDone's Avatar
Good to know for the next time I order pumps.
Old Nov 9, 2020 | 01:47 PM
  #2366
Biggiesacks's Avatar
Titanium is extremely reactive and needs very VERY good gas coverage. Back purge, side purge, updside down purge lol ALL THE PURGE. This stuff makes stainless look like mild steel. Your welder needs to be extremely familiar with welding titanium to not totally screw it up. Ideally you want to weld titanium in a sealed chamber that is completely filled with Argon, but that's not really practical and we aren't flying around in airplanes so you probably don't need to go to those lengths.
Old Nov 9, 2020 | 01:50 PM
  #2367
kyoo's Avatar
so extreme lol. is aluminum easier to work with?
Old Nov 9, 2020 | 01:53 PM
  #2368
Almost no comparison, aluminum is easy mode.
Old Nov 9, 2020 | 02:16 PM
  #2369
Balrok's Avatar
Cool.
For Ti I just went with STM. They also source everything from Ticon, I can get it even cheaper from T14 if you get an answer on welding. I didn't have the time to worry about a local "exhaust shop" doing it right, bending it right, having all these leftover pie cuts, fitting right, etc etc. If it was a case where I was exiting out front or the sides somewhere then ya. Black friday is how it got it last year.
Old Nov 9, 2020 | 02:30 PM
  #2370
kyoo's Avatar
Cool.
yea i dont think stm would be down for customizing their product, i'm sure their jigs and whatnot are specific to what they build.
i was looking at ticon's 6x9x12 oval for the rear, and their round 17" as a resonator/mid muffler. the problem is the rest of the welding to connect those parts though, the pie cuts & bends etc. that we'd have to figure out as we went. it was indicated to me that the welding would be more or less cost prohibitive.
alternatively though, aluminum does looks like it could be promising? just as light but not as strong obviously..
