Old Dec 2, 2020 | 03:51 PM
  #2506
Balrok's Avatar
Odd that TRE recommends against MT90 not having enough film strength protection compared to the regular 75w90/140?
Old Dec 2, 2020 | 04:05 PM
  #2507
Dallas J's Avatar
Veteran: Army
Marshal said he was happy with MT90 when they had clutch front and that car sees a ton of ProSolo launches each year. Its worth the change to smooth out the clutch diff, if it does.
Old Dec 2, 2020 | 04:11 PM
  #2508
Balrok's Avatar
do the cocktail then, 2 MTL 1 MT90
Old Dec 2, 2020 | 04:14 PM
  #2509
griceiv's Avatar
our last transmission lasted 7 years of autox (which is give or take 1000 pro solo launches) on mt-90 (and it was a failed 4th gear syncro that took out the trans...). Road course work might need different gear oil but mt-90 seems fine for autox.
Old Dec 2, 2020 | 04:27 PM
  #2510
Dallas J's Avatar
Veteran: Army
Even though Jon doesn't recommend it, I'm guessing he's got the fluid choices on there based on dealing with drag cars and making the gears survive. But before this trans I always ran MT90 too and the old clutch diff was silent. Totally worth a try.
Old Dec 2, 2020 | 06:08 PM
  #2511
kyoo's Avatar
why do you think the mfactory was silent? it's def not based on fluids. i flushed tcase, trans, and rear diff today with no change. oddly enough the trans had no shavings or anything in it, while the rear diff came out completely grey. I gotta pull the preload off the diff, it feels like a 2-way diff right now. with minimal preload shouldn't the wedge drive most of the clamping force anyway?
Old Dec 3, 2020 | 05:34 AM
  #2512
Jacblack's Avatar
Originally Posted by Lumpy Sticks
I had the list narrowed down to a C7 Grandsport or a 6th gen SS 1LE Camaro. But then I said screw it, I want something brand new so that I know the entire history.
I thought about the C8 as well but once you add all the good options, they are like $80k and at least a year out. If you have never driven a mid engine car, it takes some getting used to. Thats part of the reason I never drive my other car. Its just weird on the track being mid engine. I come from the front engine rwd world and miss it.
C7s are going for a steal right now even the Z’s because of how much mark up they had at first and then the market tanked. Tbh you could get away with getting a used one that wasn’t molested, that demographic is odd. Most of them were owned by old men that just let them sit in the garage.
The new A91 ecus are bricked from being tuned. This isn’t the first time BMW has done something like this, ran into the same issue on my e92 literally had to hunt for my specs with the build date that allowed for a tunable ecu.
I also often times toy with getting another car but then I look at how much money I just spent and how I’m pretty content with the evo being my toy and my job helps with any car itches due to the fact I drive a different car on the monthly basis.
I know I’ll never try to build a car during a pandemic ever again lol.
Old Dec 3, 2020 | 09:15 AM
  #2513
kikiturbo's Avatar
Do you mean the NS version? You have to use NS in the transmission or the friction modifier will eat the trans synchros
EDIT: Thinking about it, I cant remember if I used 75w90 or 75w140... Doesnt matter tho, switching to MT90.
over here the gear fluid for diffs and gearboxes with plate diffs is marked as LS... i.e. 75W90 LS. Normally I use motul 75W90 in my gearboxes and 75W90 LS in the ACD and diff... so was kind of wondering how the 5 speed will shift with 75W90 LS in the gearbox, since I am switching to plate front diff... I had some ideas about modding the front transfer to oil the front diff from the transfer and not the gearbox... but have no time for that now..
Old Dec 3, 2020 | 10:35 AM
  #2514
LetsGetThisDone's Avatar
MT90 is a gl4 fluid. 75w90/140 is a GL5 fluid meant for hypoid gear sets. Hypoid gears put A LOT more load on the fluid because the teeth literally slide across each other. GL5 also typically has a slighty higher kinematic viscosity vs the same weight GL4. On top of having a lot more extreme pressure additives, it helps the gears live longer.
I switched to 75w90NS in my trans and shifts the same as MT90, but my straight cut 4th gear is quieter.
Old Dec 3, 2020 | 11:47 AM
  #2515
kikiturbo's Avatar
Thanks for that info.. I was worried that the LS fluid might mess with the shift quality. Will run an inline oil filter in the trans cooling circuit to get some of the plate diff material out of the circulation..
Old Dec 3, 2020 | 12:30 PM
  #2516
I'm NOT using LS fluid. It's NS fluid... as in No Slip. There are no friction modifiers added to the NS fluid. Which is what makes it safe for synchro transmissions.
Old Dec 3, 2020 | 12:42 PM
  #2517
kikiturbo's Avatar
ok, thanks for the info... I have yet to see a NS oil over here, hence the confusion..
Old Dec 3, 2020 | 08:22 PM
  #2518
kaj's Avatar
kaj
NS = NON slip
LS = Limited slip
They are opposite.
It sounds like you don't want to use the LS fluid.
Old Dec 3, 2020 | 09:52 PM
  #2519
kikiturbo's Avatar
ok, but my plated front diff "asks for" LS fluid...
Old Dec 4, 2020 | 08:37 AM
  #2520
Balrok's Avatar
Well...that's a rock and a hard place lol. May end up having to use a cocktail of sorts to find a happy medium if the Tranny is indeed the fluid used in the front diff only. I thought it had 2 separate areas?
