Old Jan 28, 2022 | 06:18 PM
  #4141
kyoo's Avatar
got the 5 bolts out. how do we get the hub out? axle is loose/can be pushed in
Old Jan 28, 2022 | 06:49 PM
  #4142
Dallas J's Avatar
Veteran: Army
I thread the bolts in a few turns and use a punch to walk it out.
Old Jan 28, 2022 | 06:56 PM
  #4143
kyoo's Avatar
the 4 that held the bearing/assembly?
Old Jan 28, 2022 | 07:50 PM
  #4144
kyoo's Avatar
done for the night, started on the fronts and that's about it. saw in another thread you can rent a similar tool as the mitsubishi one from the store, and that plus slide hammer should get it off, though i have a feeling it's just going to break the wheel bearing.
Old Jan 28, 2022 | 08:41 PM
  #4145
Ayoustin's Avatar
Didn't you say you're putting SSB rear uprights on? If so just pull the upright with the bearing and parking brake still on it. Remove those from the upright after it's off the car, way easier to get access to the rear and wallop it out.
Old Jan 28, 2022 | 09:20 PM
  #4146
kyoo's Avatar
yea. trying to take care with it I guess. do I disconnect the parking brake cable?
Old Jan 28, 2022 | 10:16 PM
  #4147
ViciousLSD's Avatar
I think that bearing was already broken, thats why the guy in the video is replacing it. I had one front bearing that separated like that, but the wheel was already wobbling so I was going to replace both fronts that day. i've never had a hard time removing any of these bearings.
I think its not bad to apply a bit of jack-lift on the flange, turn it half way then lift it a bit. its similar approach to wheels stuck on the hub bores
ayoustin has the best idea though
Old Jan 28, 2022 | 10:44 PM
  #4148
kaj's Avatar
kaj
My Lord, after reading this thread, I'm glad to never, ever be swapping uprights.
what a mess. Whew
Old Jan 28, 2022 | 11:11 PM
  #4149
ViciousLSD's Avatar
what a mess. Whew
It's not that hard man. when i remove the axle(s) i actually disconnect control arms/ball joints, except the bottom(trailing arm). i make sure I dont damage the axle boots. if you disassemble once a year no part will ever freeze up :P
Old Jan 28, 2022 | 11:17 PM
  #4150
ViciousLSD's Avatar
@kyoo "while you're there"
Old Jan 29, 2022 | 08:09 AM
  #4151
kyoo's Avatar
fronts came out super easy and assembling the uprights now
ball joints basically slid out didn't even need the separator
Old Jan 29, 2022 | 08:33 AM
  #4152
kyoo's Avatar
oh boy.
ps wheel hub needs to go on first before the steering arm
Old Jan 29, 2022 | 09:04 AM
  #4153
Dallas J's Avatar
Veteran: Army
Oh dang, I totally forgot about that. Sorry man. When I beefed up the steering arms way back in the day I had to slightly block one of the bolt. Really you just need to have one bolt inserted and you can remove the hub without the steering arm.
Old Jan 29, 2022 | 09:19 AM
  #4154
kyoo's Avatar
no worries assembling off car anyway. very nice parts
rented a slide hammer for the rears
Old Jan 29, 2022 | 11:02 AM
  #4155
kyoo's Avatar
is it a problem if i don't have washers on my front axles behind the axle nut? not sure why i don't have them, they're dss axles
rears came out super fast with the slide hammer
