Old Jan 17, 2023 | 05:22 PM
  #5026
Jaraxle's Avatar
Originally Posted by TimC909
All this talk of solid state relays, has anyone tried a Kaizen Speed relay yet?
Speaking of solid state fuel pump solutions for Evos....
Is the Kaizen solution like this?
OEM ECU controlled DIY dual voltage big pump controller - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
Old Jan 18, 2023 | 06:28 AM
  #5027
deeman101's Avatar
The crydom SSRs come up a lot on google for pump controllers. I don't think they were specifically made for automotive applications like the Hella SSR. Crydom makes a lot of residential and industrial relays. But it does seem like a lot of people on the internet use it with success.
Old Jan 18, 2023 | 08:31 AM
  #5028
TimC909's Avatar
Kaizen Relay – KAIZENSPEED
Hopefully the link works. These relays can be joined together, controlled by CAN with a module that joins on the side. Pretty flexible things.
I like the MSD thing that Shaun has posted though.
Old Jan 18, 2023 | 12:39 PM
  #5029
deeman101's Avatar
They look interesting. Only thing is the pwm frequency seems low at max 225hz.
Old Jan 20, 2023 | 08:21 AM
  #5030
Terror Rising's Avatar
We took the keys to this garage yesterday. Let the fun begin!
Old Jan 20, 2023 | 08:44 AM
  #5031
Dallas J's Avatar
Veteran: Army
Do you have to share with the wife or will she let you have it all?
Old Jan 20, 2023 | 09:10 AM
  #5032
She just bought an IS350 F-sport so she gets the two car side since she can't park a car to save her life. In her world parking on the line is the same as parking inside the lines. I can always build a second garage at the tail of the driveway. I might put up a guardrail to protect the Evo for the meantime.
Old Jan 20, 2023 | 09:26 AM
  #5033
BLACKzj52's Avatar
Building a 64 based 2.2L after my stock rod decided to put numerous holes in the block. These damn custom pistons for the 64/94/156 combo seem to be a pain in the ***.
Can anybody check my information regarding specs I am going to give to Wiseco, please? I've compiled most of this info from searching around both the forums and Wiseco's site.
Block Height: 235mm (4G64)
Stroke: 94mm
Rods: 156mm
CR: 9.0:1
Cylinder head CC: 43cc
Compression Height: 32mm/1.248"
Volume: -21cc ?
Deck clearance: 0.3mm ?
Headgasket: .042"/1.1mm (stock evo 9 1005A700)
Old Jan 20, 2023 | 11:02 AM
  #5034
LetsGetThisDone's Avatar
Stroke: 94mm
Rods: 156mm
CR: 9.0:1
Volume: -21cc ?
You don't want the stroke/rod/piston to add up to zero deck. Best way is to measure current deck clearance with knock comp height pistons.
Also, stock 9 head gasket is .051".
Shoot for .010" in the hole. By the time the deck gets resurfaced, it'll prob be more like .003-5" in the whole.
Old Jan 20, 2023 | 01:05 PM
  #5035
Construct's Avatar
That's a great purchase.
Looks like it comes with a bonus house attached, too.
Old Jan 20, 2023 | 02:05 PM
  #5036
kaj's Avatar
kaj
she gets the two car side .
Ouch
Old Jan 20, 2023 | 03:33 PM
  #5037
She's the breadwinner. I'm just a Director of Engineering while she's a CFO. She has way more money into this than I do.
Old Jan 20, 2023 | 04:37 PM
  #5038
Dallas J's Avatar
Veteran: Army
Lawdy, with them titles I expect a 10car garage
Old Jan 20, 2023 | 04:42 PM
  #5039
RallySport9's Avatar
Not if you're raising kids. Each one costs about as much as a ten car garage.
Old Jan 20, 2023 | 04:52 PM
  #5040
Dallas J's Avatar
Veteran: Army
I got one (8 y/o), it aint that bad :P.
