Old Jun 4, 2021 | 08:13 AM
  #3196
Ayoustin's Avatar
Originally Posted by kyoo
do any of you guys camp on site for track (not rv)? curious how the logistics go. if it's just me and not the gf and dog, i bet i could manage no problem. my hotel bills are as high as my gas bills for these trips and half the time the hotel sucks anyway
Yes, entirely depends on how comfortable you are camping. The GF and I go on a few camping trips a year so we decided to pick up a roof tent for those and track weekends. The weave is super thick, has a bunch of netted privacy windows, a built in king size 3" foam mattress and built in lights. Setup takes like 10-15 minutes.
Old Jun 4, 2021 | 11:23 AM
  #3197
Ayoustin's Avatar
Super happy with the fitment on the cam sensor housing. Have some minor tweaks to sooth my OCD but overall happy that the first protos are usable!
Old Jun 4, 2021 | 01:26 PM
  #3198
kyoo's Avatar
well... asm is pretty sure i've got an engine failure on my hands. engine's making a clacking very similar to ben's evo when he had a wrist pin failure.
sad thing is i didnt even get to drive the car. i picked it up after new cams, loaded it up the trailer, and had tom o'gorman give it a spin. apparently cut boost, cut timing, and we're just dealing with it now.
kind of can't even believe it. no knock or anything
Old Jun 4, 2021 | 01:49 PM
  #3199
RazorLab's Avatar
might be the tensioner if you just did cams
Old Jun 4, 2021 | 01:51 PM
  #3200
kyoo's Avatar
timing belt tensioner failing?
Old Jun 4, 2021 | 02:02 PM
  #3201
RazorLab's Avatar
Could be. take the cam cover off and see what the belt feels like
Old Jun 4, 2021 | 02:04 PM
  #3202
kyoo's Avatar
what should it feel like? i did find this video, which it kind of sounds like:
in thie video it says timing disc on crank, no idea what that means
Old Jun 4, 2021 | 02:12 PM
  #3203
Biggiesacks's Avatar
The video doesn't work, but my guess would be #17.
maybe also relevant. These are all the timing marks lined up.
When my tensioner failed, I jumped a tooth. I was able to diagnose that by attempting to align the marks as shown above, and the exhaust cam did not line up.
Old Jun 4, 2021 | 02:22 PM
  #3204
kyoo's Avatar
but if it were off, it wouldn't have run fine the last couple laps? unless u think it jumped?
Old Jun 4, 2021 | 02:25 PM
  #3205
Well in my case it sounded like bad lifter tick, but I otherwise didn't notice much of a change in how it drove (commuting). At first I proceeded to diagnose it as if it was lifter tick. After discovering it had jumped a tooth, I pulled the timing cover and found the guts of the tensioner down by the crank. What I thought was lifter tick turned out to be valves contacting pistons.
Old Jun 4, 2021 | 02:35 PM
  #3206
kyoo's Avatar
tbh, that just makes more sense to me. i know the racefab and kiggly and stuff isnt infallible, but it just seems crazy to think a wristpin or something suddenly failed. i realize it's possible and the car is pushed hard no doubt, but just right after the cams like this, after being zero issue powertrain wise... idk
Old Jun 4, 2021 | 02:51 PM
  #3207
kyoo's Avatar
he's doubtful but I'm heading back to the track and hopefully it's easy to look and rule it out at least
Old Jun 4, 2021 | 02:56 PM
  #3208
It's pretty quick and straight forward to check the cam timing. No special tools or anything required. My guess is I could probably do it in 10-15 minutes. Unless I'm forgetting a step or something.
Old Jun 4, 2021 | 05:28 PM
  #3209
kyoo's Avatar
all the timing stuff was spot on
Old Jun 4, 2021 | 11:00 PM
  #3210
deeman101's Avatar
Sorry for your engine troubles kyoo. Part of the reason I've been slow AF putting everything together is because so much is changed I don't want to find out what all goes wrong.
I have my subframe out right now....thinking of switching back to OEM swaybar bushing and maybe steering rack bushing. Mainly because the whiteline poly stuff has been squeaky. Does anyone think they I'll really miss poly bushings in these areas?
