Old Mar 14, 2023 | 03:12 PM
  #5221
ViciousLSD's Avatar
maybe you can drop this drum pump in a smaller container
https://www.ebay.com/itm/385392209937
I may try it one of these days
well i tried it. it took about 15mins of pumping (a quart) I didnt have to fight the stiff hose tho
I should have gotten the 24v pump
Old Mar 17, 2023 | 10:57 AM
  #5222
kyoo's Avatar
i'm out of town for a while away from the car - does anyone know/can take a quick measurement on how long the stock cat is? trying to do a mid-muffler fitment and I don't recall. somewhere around 22" or so? It's a standard size for all the aftermarkets that sell test pipes and whatnot.
nvm: https://www.evolutionm.net/forums/ev...ength-cat.html
Old Mar 18, 2023 | 05:30 PM
  #5223
LetsGetThisDone's Avatar
New turbo kit going in. Artec manifold, g30-770, Garrett 45mm gate, and Koyo 42mm radiator.
Attached Thumbnails Sup w/them 2026 Spring Projects?-photo291.jpg   Sup w/them 2026 Spring Projects?-photo139.jpg   Sup w/them 2026 Spring Projects?-photo849.jpg   Sup w/them 2026 Spring Projects?-photo879.jpg   Sup w/them 2026 Spring Projects?-photo315.jpg
Old Mar 18, 2023 | 06:34 PM
  #5224
Jaraxle's Avatar
Oh hell yeah.. I can't wait to put in m ARTEC manifold for the Evo X... The quality of the stainless steel cast is just 100% perfect...
Old Mar 18, 2023 | 08:01 PM
  #5225
The stock frame X manifold is an excellent piece. We've done 3 of them with the MHI-18k turbo. Made 20-25whp more than typical stock manifold numbers with the 18k (all were 480+ vs the usual ~460), and no loss in spool up.
Old Mar 19, 2023 | 06:14 AM
  #5226
dr_latino999's Avatar
Veteran: Army
Nice, how soon to some numbers or feedback?
Old Mar 19, 2023 | 07:48 AM
  #5227
It's going to fab for new O2 housing/downpipe and LICP this week. So hopefully on the dyno the following week.
Old Mar 19, 2023 | 09:21 AM
  #5228
Veteran: Army
Great, fingers crossed. I'm absolutely interested in the spool-up characteristics on the single scroll v-band. Will the wastegate vent through the hood, or dropping it back down?
Old Mar 19, 2023 | 10:32 AM
  #5229
Bee-Raddd's Avatar
If u scroll up slightly i just put my dyno chart up of a G30-900. 770 will spool up probably 500rpm sooner but make slightly less power
Old Mar 19, 2023 | 03:13 PM
  #5230
Veteran: Army
Thanks, eye balling the 900 and converting to hp, I'm seeing:
4000 - 174hp
4500 - 268hp
5000 - 549hp
5500 - 616hp
6000 - 643hp
7000 - 683hp
Old Mar 19, 2023 | 03:24 PM
  #5231
Sort of.
its has 400Nm (approx 300wtq) at 4400ish. It's a dynapak and those notoriously read high. The G30-900 is a turbine flow limited turbo, very mismatched wheel sizing. Based on how much boost I've previously made 615whp with a g30-770 where we ran out of injector, I think my setup will spool faster and make similar power to Brad's. Mine will also be on a dynojet.
Old Mar 19, 2023 | 05:07 PM
  #5232
Bee-Raddd's Avatar
Sort of.
Ive run on numerous dyno's and its always been between 505 - 510kw. This dyno is known to read a little low if anything.
It comes down to what TCF people use. People like to inflate their TCF to make the power figures look better than they are.
Old Mar 19, 2023 | 06:03 PM
  #5233
Maybe in upside down land it's different ( :P ) but in the US dynapak's tend to read 5-10% high and their spool characteristics don't ever seem to match a street data log.
Old Mar 19, 2023 | 07:56 PM
  #5234
Bee-Raddd's Avatar
Yea like i said its all down to the tuner and how he sets the correction factor up on the dyno. Lots of people put in cheeky TCF's to get their numbers slightly higher so they look better than they are. which is what your noticing. Im not sure if its possible to fiddle with a dynojet.
But what your seeing is tuners who have dynapaks inflating their numbers rather than the dyno itself reading high. Its something i always check when they give me a dyno chart to confirm that its not inflated
Old Mar 30, 2023 | 04:59 PM
  #5235
This is NOT my car, but another one we've built here at the shop. And I'm excited to finally have real results with this turbo on a dyno jet dyno and plenty of fuel system. This literally ALL OF IT, an additional 15% (in 5% increments) wastegate duty cycle didn't make more boost or power. It doesn't layover hard like its has back pressure, so I think this all the compressor flows. This was 30 psi ramped to 32 out the top. Didn't want to make more torque on the Exedy twin.
Evo8, 4g64 2.2, Headgames pocket port, GSC R2 cams, ETS Vband G30-770 Kit 1.01ar hot side. RMC spec fuel system.
