Old Mar 25, 2024 | 07:20 PM
  #5971
CaptainSquirts's Avatar
What do you mean by the front bushing still being round?
Old Mar 25, 2024 | 07:38 PM
  #5972
ViciousLSD's Avatar
is this an offset bushing, if so then it moved the control arm slightly so you might need to stretch the front bushing a bit so the rear holes line up
Old Mar 26, 2024 | 06:48 AM
  #5973
Terror Rising's Avatar
Did you already tighten down the front bushing? If so, loosen it up and pull that arm back. It'll go it just takes some force.
Old Mar 26, 2024 | 09:32 AM
  #5974
Ayoustin's Avatar
This is exactly why factory or poly forward bushings suck with offset compliance bushings, because the bolts are no longer on the same plane so the forward bushing needs to be forced out of alignment to get the bolts in, which creates a **** load of stiction in the arm and makes them a **** to install. Grab a bigger prybar.
Old Mar 26, 2024 | 09:34 AM
  #5975
LetsGetThisDone's Avatar
Yeah. Gotta put the front bolt in first. But leave it loose. Then use a pry bar to move the arm over and get the rear bolt in.
Old Mar 26, 2024 | 10:48 AM
  #5976
Alright I was able to get the control arm installed. I initially had the washers/spacers on the bottom of the rear bushing since I thought it was going to smack the cage where the rear bushing is. When I first tested it I didn't even have the control arm attached to the hub so I can literally make the control arm swing down as much as I want until it smacked the cage it was in. So I put the washers at the top of the rear bushing and for some reason, it was way easier to get the bolt all the way in. I had the front bolt out when doing this and installing the front bolt afterwards was super easy.
I appreciate all the tips/advice every gave!
Old Mar 26, 2024 | 10:51 AM
  #5977
ViciousLSD's Avatar
you need to make sure the front bolt itself is lubricated, or else the stiction will turn that lefty-loosey
Old Mar 26, 2024 | 10:53 AM
  #5978
It's slathered in antiseize, should be goochi
Old Mar 26, 2024 | 10:59 AM
  #5979
Dallas J's Avatar
Veteran: Army
Also, torque it to a real spec and not "feels good enough".
Old Mar 26, 2024 | 11:52 AM
  #5980
ViciousLSD's Avatar
cool. its only until the bushing takes shape.
time to fit 295s
Old Mar 26, 2024 | 11:59 AM
  #5981
Construct's Avatar
time to fit 295s
You had 295s already, right? So now it's just tweaking the alignment?
Old Mar 26, 2024 | 12:03 PM
  #5982
ViciousLSD's Avatar
depends on how high the car is and if that damned seam weld was addressed already. short springs. after that its just taking the heatgun to push out the fender lining. it may have a slight rub at full lock
Old Mar 26, 2024 | 01:35 PM
  #5983
I can’t imagine going past 265/18. Curious on what STU peeps do to fit fatter tires.
Old Mar 26, 2024 | 01:40 PM
  #5984
MrAWD's Avatar
I am running those as my daily size tires - back in hoosiers in Stock class time, I was running 285s - all without doing any changes anywhere.
From what I have heard, EvoX can go all the way to 295s. Yet, if I got to get there eventually, I might rather use 285s because they are shorter
Old Mar 26, 2024 | 01:48 PM
  #5985
ViciousLSD's Avatar
by 0.2" (divided by 2) lol
