oh that aint ****. maybe 20 more lbs for the 6spd, there was always a 20lb diff between MR & GSR listed specs. thinking i might just pop by and put the trans in the trunk and take it to TRE, rather spend $500 for back and forth shipping for a 2 1/2 drive.
Yea two people can lift the transmission with ease. Its like a washing machine in terms of weight. Shipping is way too expensive right now. I tried to ship out a set of wheels and the prices were the highest I have ever been quoted.
Crazy my car is 21 years old now... Original owner really haven't driven my car or done anything with it since 2015 when I had my engine/trans/t-case build. I hit a deer with my DD and drove the Evo and fell i love all over again. Decided to do some restoration, comfort things which turned into a pretty large project. I'll take you through my journey of the last 40 days.
All started with:
-Refreshing all 4 window moldings
-HVAC control link gears (couldnt move the hot/cold) and new OEM labels
-New Trunk Carpet and Floor board - 21 years of use they were pretty bad
-New Under Hood Insulator
Then I thought Hum the OEM speakers suck.... so swapped all the speakers out with some nice Sony speakers and my double din radio was so old it didnt even had bluetooth connectivity so decided on ordering a tablet style one to replace it so I can have modern functionality and connect my phone for some music.
This lead to me thinking this steering wheel has seen better days so I ordered a custom steering wheel, along with custom carbon fiber dash trim to go across the dash.
So after feeling pretty good about things and still waiting on the custom parts I was having a blast with my car again. After doing some spirited driving I decided to just look under the hook to make sure nothing looks SUS and of course a small crack in my headers which cracked 3 years ago. I decided let me order a new one to find out ETS stopped making this exact one. So this is where things really went crazy and opened the can of worms. I decided not only to get new updated headers which required me to get a re tune but why not just order an entire new turbo kit! So got a G35-900 with quick spool headers! Ended up putting down 636whp on pump and 820whp on E70 (very conservative tune)
If that wasnt enough I've been addicted again to watching Evo things on YouTube since I'm all energized again and financially in a good place. So while its at the shop decided why not just get some more stuff done:
-Ohlins R&T Coil overs
-Whiteline Front Roll Center Adjustment kit (Other one had cracked pillows)
-Whiteline rear sway bar w/endlinks, and new front endlinks.
-Somehow convinced my self to pull the trigger on the Carbing Titanium Front strut (with Titanium Hardware) bar I always wanted
-Boosted Fabrication Cross member/roll stop bar (Stock was looking rough)
-4 new wheel bearings
-4 new dust covers
-new stoptech parking brake shoes
-all brembo rebuild/re powder coated
-Tomei Ti Cat back
-Oil Cooler feed & return line replacement (they had a slow leak)
-Blox Test pipe (going to weld Vibrant Ultra Quiet resonator into)
-Titanium engine bay hardware replacement kit complete to include axel nuts, brake bleeders, Oil Dip stick Trial BOV hardware, and a few other Ti parts
-Torque Solution Adjustable Rear control arms (Stock one were very rough and for the same money to replace bushings I can get these)
-Driveshaft Center Support Bearing carriers (stock ones are looking sketchy)
So Very interesting to say the least and wasn't expecting this and all due to a Buck that decided he wanted to hide in the bushes and take out the Tesla last minute. I'll have to do a post when its all done but I'll throw a few picture up in the meantime.
ill post pictures when I get it, look them up
On YouTube quality work.
Thanks man. Definiltey going to go with them. That's just beautiful. Our wheels looks so much like the 2006 Lamborghini Murcielago (except better honestly less fat) and I think they're just the most attractive wheel of any import of it's time. Also where did you source an oem carpet? These are discontinued. Did you just find a very clean used one?
Totally agree about the steering wheel. The inside of the Evo always in my mind was lacking especially compared to the STI at the time but I think I've done well so far just some final touches.
And while everything’s apart and waiting on a few final parts might as well refresh these again! Franks Powder Coating (check him out on Facebook 1 week turnaround for me) after sending mine in is only going to cost about $600.
Anyone hate when the front arm bolts get stuck in the bushes? I had to cut a subframe to get this one out (I have a spare stock subframe)
Had some spare 16 mm sphericals around.. The arms will be used only as a "stock" spare setup... Billet uprights come with a custom subframe and arms... but still.. Cut my finger on the swarf.. god I hate stainless..
I had this happen back in 2014 and had to cut, peel and reweld to get access to the captured side. I still have my front subframe recall to be performed. That should be interesting, conducting business with a Mitsu dealer in 2024. I heard if you're lucky, you can get new front lower control arms included in the recall
I grease my bolts now since one my cars had this problem back in NYC
my first issue with the subframe was the captive nut inside the subframe.. that time I cut a small hole in the subframe and welded the plate over... should have greased the other side at that time....
my old car still has the big holes i cut to access those nuts for the trailing arms . "Luckily" the metal part of the bushing had some teeth which grounded off the other side of the bracket as the bolt was being loosened
I seem to bounce back and forth between various projects as I get motivation, inspiration, and time. Our last attempt on the flares we had real bad warping on the mold doing an infusion on PLA and the heat of curing was too much.
So I put it on the side while getting other things done. Worked yesterday and today on things and now I can pull the solids out and create the molds for carbon layup. Canards I tweaked a bit from my current designs also. A bit larger and more aggressive with XA rules. Need to print these and get them off to my buddy for work so I can move on to the next fun thing.
