Old Nov 23, 2023 | 03:54 PM
  #5761
ViciousLSD's Avatar
Originally Posted by kyoo
a friend of mine was gushing over the future of electric awd systems (motor at each wheel, no lsds) and how that is superior to let's say a traditional awd system - t-case/center diff, front and rear lsds. for ease of discussion let's say a mechanical lsds. comparing a 400hp (100hp/wheel motor) electric and 400hp ice awd - aren't mechanical cars capable of sending more than 100hp to a single wheel, depending on torque distribution? I think there are also stability improvements in having the wheels mechanically linked, vs. motors mimicking the speed differences per wheel, especially when it comes to braking. this is aside from things like charging speed, heat, reliability, instant torque, management, etc.
ah the little joys of nerding out about new exciting products/tech, most of the time (in my experience) dweebs I kinda feel sorry for. lots of things looked like some 'unfair advantage' until theyre not, or never was, or was just a waste of time & money. Even on our cars its a never ending upgrades, disappointments and rollbacks
when it comes to EV's its really hard to ignore the things (and many others) you want to ignore. To be fair, even e85 has annoying disadvantages when you enjoy the benefits from time to time
A hybrid power & drivetrain would be cool like electric turbos and diffs
Old Nov 25, 2023 | 09:39 AM
  #5762
Ayoustin's Avatar
Old Nov 25, 2023 | 10:20 AM
  #5763
Dallas J's Avatar
Veteran: Army
I see a few whoopsies on them jaws and vise
Old Nov 25, 2023 | 11:13 AM
  #5764
Ayoustin's Avatar
Hahaha yea, they do a lot of die cast molds so I'm sure their usual tooling goes through their vise just as easily as the stock they're normally machining lol
Old Nov 29, 2023 | 09:40 AM
  #5765
kyoo's Avatar
anything to consider while i've got the trans out? not planning to go to a 5, i'm actually pretty happy with how well the 6 speed held up over 30k with all sorts of abuse.
they don't make those fancy albins gears anymore do they?
Old Nov 29, 2023 | 10:47 AM
  #5766
ViciousLSD's Avatar
theres a 30% free s&h BF sale on ACT stuff
maybe a good time to relocate the ACD pump, clean up battery cables
Old Nov 29, 2023 | 11:14 AM
  #5767
kyoo's Avatar
yea I've got the ACD pump relocated and the battery relocated to the trunk.
Old Nov 29, 2023 | 11:16 AM
  #5768
ViciousLSD's Avatar
not sure if its a good idea, there's WL bushings for the steering rack
Old Nov 29, 2023 | 11:28 AM
  #5769
kyoo's Avatar
think i've got those too, haha. all of those stuff - bushings, other small ancillary parts in the area, etc - pretty much all that stuff has been done at one point or another.
Old Nov 29, 2023 | 12:31 PM
  #5770
ViciousLSD's Avatar
check the for corrosion in the coolant plumbing. CV boots? oil seal? braided line for clutch? can be done later tho. also requires the monoloc IMO if anyone else was planning to do it
see if you could be interested in ayoustin's products around this area
otherwise just clean the area while the trans is out
Old Nov 29, 2023 | 12:41 PM
  #5771
Ayoustin's Avatar
Ooooweee just waiting on the proto trans mounts to come in and then we'll be making official announcements for all the mounts. If anyone is going to be at PRI next week these will be in the Evo on display at the Go Fast Bits booth!
Old Nov 29, 2023 | 02:13 PM
  #5772
griceiv's Avatar
are they full thickness poly inserts or is there a big gap in the middle?
Old Nov 29, 2023 | 06:38 PM
  #5773
Ayoustin's Avatar
They're not quite full thickness but definitely thicker than the bushings TS uses. Center gap is 20mm on the side mounts, 3mm on the front mount and 13mm on the large bush in the rear mount, the small bush of the rear mount has no gap. We could get custom bushes made to not have gaps but it'd hike price up a good amount and wouldn't really affect life or performance of the bushing. The bushings used in the side mounts are each 31mm thick for reference.
Old Nov 30, 2023 | 07:23 AM
  #5774
griceiv's Avatar
That definitely sounds like an improvement over the TS mounts. Any plans to have replacement bushings available?
Old Nov 30, 2023 | 07:30 AM
  #5775
Evo9isLife's Avatar
5 Year Member
Are you making a 6 speed trans mount?
