Quote:
. [/i]
You do know that the arrow is there to identify the location of the wear indicators and not a camber alignment guide?Originally Posted by kaj
That's where it rolls to. I assumed I'd want it going to where the arrow is actually pointing. Made the most sense to me. Quote:
I'm on Falken 615s so they wear pretty good. Traction is a different issue. Originally Posted by letsgetthisdone
With that mileage and number of events you'll be doing, the street driving will not be what wears your tires out. I would definitely align the car for max performance at your driving events.
Quote:
Why do you even have a street set of wheels/tires!? You barely drive it!Originally Posted by kaj
I drive the car about 20mi, once or twice per month. If I drive to BWRP, it's 220mi round trip but that's why my "daily" tires are so cheap. No worries LOL. I only go there 2-3 times per year and only drive the car there one or two of those. Zero toe.
kaj
close
- Join DateMar 2006
- LocationFresno, CA
iTrader Positive Feedback100
iTrader Feedback Score(60)
Liked:824 Times in 685 Posts
Quote:
I don't use them to align camber. Originally Posted by griceiv
kaj
close
- Join DateMar 2006
I don't want to drive to cars and coffee on $1000, 100tw tires (I WILL pick up a nail). Also, I occasionally drive to my "local" track which is 110ish mi each way. Again, I will, absolutely pick up debris. Originally Posted by Lumpy Sticks
I'm on Falken 615s so they wear pretty good. Traction is a different issue.Why do you even have a street set of wheels/tires!? You barely drive it!
Also, I was 100% lazy and exhausted after an event there, so drove home on the Nittos. So noisy, I pulled over because I thought something was wrong with the car. LOL They did NOT like cement freeways.
I assume you have NT01s. I have them on my bug. I dont think they are loud but it's hard to say since everything else about the car is so loud. They do pick up a ton of rocks though.... awesome tires.
kaj
close
- Join DateMar 2006
Quote:
On asphalt they were fine.. just the cement sections, which is from the track until about 20-30mi down the freeway. The tires were whining so bad, I thought my t-case was on it's way out. It was LOUD. My car is also gutted and reverberates everything like a drum, so then there is that Originally Posted by Lumpy Sticks
But I could hear it over the stereo blaring and through my ear plugs. Quote:
You said the tire rolls over to where the arrow points, so its good. That is not what the arrows indicate. The arrows are way off the tread, if the tire is rolling over that far you do not have enough camber.Originally Posted by kaj
NT01's are loud as hell at full depth. Whoever says otherwise is hard of hearing.
Here is my car with a fresh set of NT01's. You can literally hear the tires well before you see me in this recording. Sounds like a Tie-Fighter. lol
Another one, about 125mph:
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
iTrader Feedback Score(1)
Liked:1,629 Times in 1,392 Posts
Quote:
This.Originally Posted by griceiv
This is kinda what I was getting at with the wear should be to the "edge" the arrow is pointing at, not to the arrow.
I forgot the arrow indicated that's where the tread wear bars are. Old tech info from working at discount tire...lol
And yes, NT01's are load as ****. Louder than any mud terrain or off-road race tire I've had on any of my trucks. Including grooved short course tires.
Biggiesacks
close
- Join DateAug 2005
- LocationWest Coast
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:708 Times in 595 Posts
please excuse my track car ignorance, but aren't you suppose to use a pyrometer on the tires to determine what you should do with your alignment at the track?
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
Quote:
That would be ideal. But in the absence of a pyrometer you can also monitor how the tire is wearing. Also, sometimes "ideal" tire temp readings don't make the car handle how you want it. So it's kind of just one "part" of the chassis set up tool kit.Originally Posted by Biggiesacks
Even a pyrometer is going to lie to you. Watch some vids of cars with IR temp sensors on the tires and you'll see how fast the temps normalize across the surface. Its seconds. Basically you dont have enough time to get thru a corner and get off track to check distribution. Plus the braking as you come off is going to add heat to the inside.
Pyrometer is really best used in a dedicated skid pad where you can pull off immediately and have an assistant measure. But in general, looking at tire wear across the tread is going to be your best indicator. Also if you're in a location that picks up OPR, looking at where it builds up also will tell you where you arent scrubbing as much as the rest of the tire.
Biggiesacks
close
- Join DateAug 2005
Thanks for the enlightenment guys
I have read that the IR sensors are garbage and you need something with a probe that can get below the tire surface. I think this was recommended but I can't remember what forum i was reading about it on.
"Joes Racing 54005 Pyrometer with Adjustable Probe"
The single point IR sensors are pretty useless because the temp on the surface definitely changes too fast to measure if you arent measuring as its changing.
You can see it here really well.
The probe gives you more time, but its still not enough for coming off track and measuring.
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
That's why I said it's part of it. It definitely helped in setting up my car. It's not the end all be all thing to go off of though. We also checked the temps in the hot pit. No cool down lap.Originally Posted by Dallas J
Even a pyrometer is going to lie to you. Watch some vids of cars with IR temp sensors on the tires and you'll see how fast the temps normalize across the surface. Its seconds. Basically you dont have enough time to get thru a corner and get off track to check distribution. Plus the braking as you come off is going to add heat to the inside. Pyrometer is really best used in a dedicated skid pad where you can pull off immediately and have an assistant measure. But in general, looking at tire wear across the tread is going to be your best indicator. Also if you're in a location that picks up OPR, looking at where it builds up also will tell you where you arent scrubbing as much as the rest of the tire.
