Convert trunk mounted wing to chassis mount?
Old May 24, 2020 | 11:13 AM
OX's Avatar
OX
Any reason I couldn't do this as long as wing ends up in same spot?
Would save me from getting another trunk to trash and save me from
making trunk supports down to frame. I don't care about no trunk access.
Old May 24, 2020 | 11:37 AM
Sharkbite2000's Avatar
With a bigger wing the downforce will be a lot greater , so the trunk won't be strong enough to handle that.
Old May 24, 2020 | 12:07 PM
OX's Avatar
OX
Not sure what is considered bigger, but I was considering making new chassis mounts for an APR 67" GTC-300.
Mainly as I won't have to get another trunk, mod it, and paint it.
Old May 24, 2020 | 12:50 PM
V.8MR's Avatar
I'm semi interested in doing this also. Or at least making a mount/pad that would be tight fit right under the mount on the trunk skin.
Old May 24, 2020 | 03:21 PM
Balrok's Avatar
We spoke about this a little before. The option of a padded mount that you could "slam" it down on would eventually dent the inside area of the trunk, then you'd still have the "lift" at the front part of the trunk. The only way to do it properly is through the body as one or many pieces still.
I've pondered extending the cage to the area, mounting it all properly, then simply buying a dry carbon lid that slides on and clips down. However I'm still currently enjoying my non-active active aero you get from trunk mounting a large wing. The faster you go the more the front lifts, thus decreasing the angle, thus decreasing drag. So I tell myself anyway lol.
V.8MR
Nov 17, 2019 03:54 PM
Nomad4g63
MitsubishiParts.net - WA
May 14, 2011 02:44 PM
Joemflsxe
Southeast Region
Feb 8, 2011 08:59 AM
fastkevin
Jun 5, 2008 12:56 AM
JT_EVO8
Aug 15, 2004 12:02 PM
