Cams and Emissions
Cams and Emissions
I, as well as many others would like to know what cams/cam combo's will pass emissions. I live in MD, so we have emissions every 2 years. So hopefully there are some 03's out there that have been thru that can provide some insight on this topic.
I know this has been a topic that has been debated about for some time, but I am looking for hands on experience.
The questions is whether or not 272's with or without stock ecu (flash) and cam gears will pass emissions?
I know that the increased lope with the 272's will not make anything easier as far as passing goes...But will they pass without alteration of the ecu/cam gears?
If you have to have a sniffer test, I highly doubt you will pass with cams, especially HKS 272's. I know from personal experience with DSM's with cams they wont pass a sniffer test. But doesnt hurt to try right? Unless they mark you as a gross polluter.
Scott
05 GSR w/SSL
92 Talon Tsi AWD
Scott
05 GSR w/SSL
92 Talon Tsi AWD
I am from PA and just had my inspection with emissions done. We have it EVERY year, so don't complain too much! I have an 03 with HKS 264's with a Utec and it passed fine. As long as you have a Cat on, and don't have any engine codes pop up, you will be fine.
Just a hint, try to take it to a local shop and not the dealer. They tried to jack me around about the engine codes and what not, so I left. I took it some place else and it was fine.
But back on topic, I dont think you will have a problem with cams passing emissions. Unless you somehow get a PO300 (?) from the install, which can easily be cleared. As long as there are no codes, you should be fine. GL!
supak111
Mar 14, 2016 09:10 PM
