Connecticut Evos
Old Jul 10, 2008 | 07:19 PM
  #301
boybeatertsi's Avatar
Originally Posted by staatz
How much did tonys car put down with the 30r if hes still got that? Was this the car used against "coco"?
His evo never had a 30r on it .. Tony's car made 448hp with pump gas, stock ecu and a 62-1 .. it's got a different turbo and aem now .. yet to be dyno'd ..
Naw he raced coco with the hyundai.
Old Jul 10, 2008 | 07:27 PM
  #302
Mulholland0132's Avatar
Wow not to be super gay but we should have a 35R party here in CT.
evoracing star
andreww238
dafoe69
I can't believe how many cars are running this size turbo on the street. I thought building my car with an hta35r was going to make me special.
As Ive said in the past I really want to meet some of you guys that I haven't already met. Its never a waste of time to meet other people who have the passion for making these cars put down crazy power.
Old Jul 10, 2008 | 07:54 PM
  #303
evoracingstar's Avatar
evoracing star
andreww238
dafoe69
ik right u wait im in the process just saving money! motor coming next thinking about built 2.3 or even a 2.0 not sure yet!
Old Jul 10, 2008 | 08:13 PM
  #304
dafoe69's Avatar
evoracing star
andreww238
dafoe69
We should see about a CT meet at some point I can even remember the last one. Don't know if I mentioned it but mine is a HTA too. Got that, a double pumper, 1000cc's, and a few small things going in tomorrow/saturday. I'm curious to see if the coating on my manifold shows any impact. I had Shearer do a ceramic coating on the outside and insulate coating on the inside. To quote Shearer on the insulate coating "The coater said that he had done a test recently on a blown big block drag car on the dyno. He said the headers never got above 300deg Fahrenheit when shooting the outside of the header with a laser temp gun"
Old Jul 10, 2008 | 08:29 PM
  #305
Pruven's Avatar
evoracing star
andreww238
dafoe69
Hey Eric.... Don't you think your signature is a little over the top??? LOL!!! Thanks though!!!
Dan
Old Jul 10, 2008 | 08:32 PM
  #306
Pruven's Avatar
Originally Posted by boybeatertsi
Jezebus.
Kenny at THESHOP is a nasty tuner here in CT .. he tuned by boyfriends evo 8 and the thing is money!!
"The SHOP" is closed from what I understand. The owner opened up in a diiferent location and is called something like Triple Ace Motorsports.
Dan
Old Jul 10, 2008 | 08:35 PM
  #307
Dan
Im just sick of all the haters...and internet tough guys are a dime a dozen...so I figured what the hell...let them say this crap in person.
Old Jul 10, 2008 | 08:36 PM
  #308
andreww238's Avatar
staatz is also fully built.. 2.3l 37r in CT
Old Jul 10, 2008 | 08:45 PM
  #309
Pruven's Avatar
Yeah, we built his motor!! Sean Ivy made 680 wheel horsepower with it just the other day!!
Dan
Old Jul 10, 2008 | 10:11 PM
  #310
yezzz sirr! tim is the man!!
Old Jul 11, 2008 | 12:50 AM
  #311
DynoFlash's Avatar
Originally Posted by evoracingstar
hey al i ant trying to put u down, your a great guy, i just didnt like the way u treated me while i was there. yeah maybe someone stressed u out eariler and u took it out on me. idk. but with the dump tube as u were saying it make loud noise/vibration bc the way it is located. i called up buschur and talked to them, they said they never had one problem with one of there kits they sold that the wastegate dump tube would through off the knock sensor. i also log my car al, and pick up no knock, idk what ever it is im going to have ivey take it look at it for me see how that goes from there. i didnt want to start no arguements, bash talking, none of that.
I appreciate your comments. Please accept my sincere appology if I offended you in any manner, this was not my itention.
It is interesting to me that you report that you are not picking up knock at this time.
Please refresh my memory, did we try diagnosing your car with some race gas at the time we did the tuning session? Its hard for me to keep all these evo m names and real names straight and I can't remember exactly what we did when we tuned your car. We must have done something as you mention the price of $450 that you spent but for existing customers our retune is priced lower than that. Did we perform any mechanical services at the time such as boost leak test or adjusting the springs in an external wastegate?
If your car was showing knock counts when it was on our dyno and now it is not showing knock counts then the "problem" may be as simple as a bad tank of gas. That is why I am asking if we did the race gas test?
Usually the kind of knock counts that alarm me are ones which do not respond to tuning adjustments (e.g. making the mixutre richer or adjusting the timing, etc). When I see a car with significant knock counts which appear unrelated to actual detonation and which appear to not be effected by tuning adjustments, it becomes un wise to complete the tune before first working to determine the cause of the condition.
Any Evo that exhibits knock counts which are unrelated to actual pre-ignition / detonation can be very difficult to tune on the stock ecu. While this condition is thankfully not very common, I have run across a good number of cars that show knock counts on the data logger even though the car is not actually detonating.
Some causes I have seen
1 - Improper cam journal tolerances
2 - Cam cap on backwards
3 - Rod bearing
4 - Stiffy motor mouth frozen
5 - Down pipe banging on sub frame
6 - Loose motor mount
7 - Loose nut inside down pipe
9 - Dump tube rattling on the down pipe
10 - Loose flywheel bolts
11- Injecting oil i the intake - (crank case breather)
12 - etc etc
Also, some cars have actual bad or weak gas and are actually knocking but not due to a tuning issue - simply becuase the gas is not of a suffficient quality.
In those infrequent cases where we run into a "knock coiunt" problem I usually ask the customer to try and go over some of the potential trouble points I mentioned abouve and also change the fuel for a fresh tank of gas - - AND - - more importantly come back for a check over and complete the tune after the diagnostoc steps are commenced.
In any event, I am pleased to hear that apparently from what you say your knock count problem is resolved. That is great news. if you change your mind about the offer for a free retune on the dynjo than our door is always open to you.
Al
Old Jul 11, 2008 | 08:30 AM
  #312
Dan
It's located in Bridgeport and I believe it's still THE SHOP .. they picked up the phone saying that the other day when I called Kenny .. I dont really care what it's called I just like what Kenny can do ..
Tony just put a 37r on his evo 8 too .. haha
Old Jul 11, 2008 | 11:31 AM
  #313
3 - Rod bearing
12 - etc etc
Al
al its brandon first time we tuned the evo with the 35r where picking up knock so we decided throw some race gas in it. apparently when i asked for c16 at xx they gave me something elts i forgot wat it was. then the lower intercooler pipe pop off so u had angel put that on for me. we tried adjusting the wastgate dump. u said the knock went down a little bit, then it went back up. then i called u up another day u said come back down ill look at it for free. i ask if u would put it on they dyno u said once i take it on the street if it doesnt pick up any knock yeah we will put it back on the dyno. so that day, u had that kid there from coloroda that u were teaching him and show some basics how to tune. do u remember now? i got the graphite grey evo. both time i was down there tim (staatz) was down there with me. so then u took the car out on the street said it is still picking up knock u said you cant do anything about it. few days later i hooked up my taxtric cable to see if it was knocking. there was nothing. idk man. its weird. ill pm u and we can talk. bc i dont want to drive another 2 hours out of my way to just have the same thing happen to me again u know al. gas ant cheap these days. lol.
Old Jul 11, 2008 | 12:24 PM
  #314
staatz's Avatar
evoracing star
andreww238
dafoe69
Can it be the 35r/37r party so I can come? =(
Old Jul 11, 2008 | 12:25 PM
  #315
staatz's Avatar
Thats good, I remember Jennety(sp?) saying it was a 30r. Either way, all his cars are fassssst..haha
