Connecticut Evos
Old Feb 10, 2009 | 03:59 PM
  #1006
evoracingstar's Avatar
Originally Posted by 1slowevo
nope. sold it last month. I am freeing up some cash for other projects. (investment properties and drag car)
ahaha awesome well i think you should to tell me what your doing! call me or pm me i think i have a idea. think the car starts with a S and ends with A? hit me up! got to come down to ct soon i got my new setup in and rdy for my tune got to call up ivey this weekend to set something out shes going to rip now!!
Old Feb 10, 2009 | 04:10 PM
  #1007
Red08EVO's Avatar
hey guys. im looking for someone who can weld aluminum good. im in beacon falls. anyone around that could help me out. I need 2 6'' pieces weld together. so just one 6'' straight line weld is all i need.
Old Feb 16, 2009 | 08:53 PM
  #1008
justboosted02's Avatar
Originally Posted by DynoFlash
If you add a second bullet muffler in the system as a resonator that will cut down the sound without hurting performance
We made 720 whp on Suman's car with that set up with the two mufflers and its really quiet
no its not
quieter than a test pipe.... yes
quiet.... no way
Old Feb 16, 2009 | 08:59 PM
  #1009
Originally Posted by Mulholland0132
Not yet.....Ive been having the wierdest issue with trying to get the car through emmissions.
I pulled the aem, went back to the stock ecu, stock map sensor, stock maf, stock egr valve, etc.....but I have been throwing an egr code the last two weeks.
Hopefully it will be figured out this weekend.
New kit is on the car. I still need to have the adaptor welded for the bov, larger fuel system in the works, throw the aem back in, and some serious tuning.
Stop rushing me man Its only February.....it will be mean and lean by March.
Now if I can just get myself back to 190lbs....I think 3,150 with me in the car at 600plus whp should be a serious highway monster.
change periphery bit 2 to 0001 and it eliminates the egr checks from the ecu and comes up as N/A on the scanner. should pass the OBD2 check
pm me if you need help
Old Feb 17, 2009 | 02:34 PM
  #1010
Mulholland0132's Avatar
Thanks.
Im going to try this out.
I'll pm you if I can't figure it out.
Old Feb 17, 2009 | 04:15 PM
  #1011
Thanks.
Old Feb 25, 2009 | 01:55 PM
  #1012
supasixfo's Avatar
rallycross
anyone know of any local rallycrosses this time of season?
Old Feb 25, 2009 | 03:12 PM
  #1013
k2boarder3187's Avatar
wheres everyone at lately?! hows the cars going
Old Feb 25, 2009 | 07:55 PM
  #1014
Red_Evolution's Avatar
just finished my build... put down 456hp/370tq at 27 psi
Old Feb 25, 2009 | 07:57 PM
  #1015
niceee! wat u running for turbo know!?? just doing a few more things to my whip then down to ivey!
Old Feb 25, 2009 | 08:05 PM
  #1016
custom 35r kit.. ya we put down 456... withouth knock... barely touched timing.. i mean.. we coulda easily went more.. but stock bottom end.. wanted to be safe
Old Feb 25, 2009 | 08:25 PM
  #1017
built head?? i cant wait to see wat i put down on stock block and stock ecu with this hta 35r
Old Feb 25, 2009 | 08:51 PM
  #1018
yessir built head... stock bottom end.. 27 psi.... 456hp
Old Feb 26, 2009 | 08:34 AM
  #1019
Im interested to see that power too
I talked to Dan last night...he said even at waste gate boost (19psi roughly) your car moves out Interested to see what that beast makes.
So I finally got my car through emmissions. What a PITA I will post some numbers in the next week or so when the car is tuned for the HTA88. Would be nice to see 600plus without race gas.
Old Feb 26, 2009 | 02:22 PM
  #1020
did the egr disable trick i posted work for you?
