TeeJay's Quest For 700+whp Stock Block discussion thread
It won't quite be a stock block any more but it's the responsible way to go. There are a couple Evo 8's in my area at 700 so there's no reason it can't be done if we're beefing up the block.
The car that makes 700whp is on a built cosworth stroker motor running one of our HTA3582 turbo kits. The car was tuned by ivey. The 3582 is pretty much maxed, but the car is not setup for drag, it's a time attack that should do very well next year. I can't wait to see the results.
Hey pete good luck! Let us know when you'll be doing the tuning before hand, I would love to be there when a new record is set !!!
Thanks man. Mine has a shield and the shield isn't even mounted to anything. They took off the piece that the stock box connects to so thats incorrect for sure. Also, mine seems to sit lower than I've seen somewhere else before.
