TeeJay's Quest For 700+whp Stock Block discussion thread
Old Oct 6, 2009 | 10:50 AM
  #61
projekX's Avatar
Originally Posted by monkey_187
I cant wait to see what it puts down, are you guys taking it to the track at all?
If i have her back by thursday or friday, she will be makin her 1st pass thursday or friday night @ ATCO Raceway.
Old Oct 6, 2009 | 11:03 AM
  #62
ETS Michael's Avatar
Originally Posted by DG Motors
Just wait till you see this beautiful IM installed
Old Oct 6, 2009 | 11:28 AM
  #63
DG Motors's Avatar
Exclamation More Updates!
Ok, This morning was all about the Blitz Surge Tank (2 piece Intake Manifold), Hks fuel rail, and Fuel Pressure Regulator.
What we didn't know is that we were going to need a few fittings and lines. Instead of taking the easy way out, we made some custom brackets and used AN fittings with S.S lines to really bling out some of this beautiful engine bay.
Check it out!
Now we are soldering and heat shrinking the injector pig tails into the main harness, finishing up the fuel system, and then re-installing the tranny and t-case. It would be great to fire this car up Tomorrow!
Old Oct 6, 2009 | 11:59 AM
  #64
cnj4ever's Avatar
awesome thread just suscribed.
GOOD LUCK
Old Oct 6, 2009 | 12:32 PM
  #65
projekX's Avatar
Oh My...
Old Oct 6, 2009 | 12:57 PM
  #66
HybridKOOP's Avatar
Awesome build. Can't wait to hear the trap speeds.
- Lou
Old Oct 6, 2009 | 01:06 PM
  #67
tkklemann's Avatar
Did you guys replace the line running from the intake manifold to the valve cover, or did you just put the SS braiding over it? If you replaced it, well, pop goes a bunch of stuff if theres no check valve in there.....
Old Oct 6, 2009 | 01:20 PM
  #68
Evo a Mula's Avatar
looks good i see you finally got eric to do some work lool
  #69
DG Motors's Avatar
Which valve are you talking about? We did not remove any check valves....
Old Oct 6, 2009 | 01:32 PM
  #70
tkklemann's Avatar
There should be a PCV valve possibly shoved into the line itself like the brake booster line on the Evo VIII's.
Take the line off the intake manifold and see if you can blow into the end of it straight into the valve cover. If you can then you are going to get 30+ psi into your valve cover. The OEM line probably has a check valve built into the line, if not, it might be built into the valve cover or possibly the intake manifold itself.
That line is an open line to push 30+ psi into your valve cover unless there is a check valve in it that only allows your intake manifold to draw vacuum from the valve cover..
Its a very easy mistake that I have seen some people do with the brake booster line on the VIII's, they remove the stock line and replace it with a slicone line and boom, there goes the brake booster because they didn't realize that there was a check valve in the line to only allow air to flow one way..
Old Oct 6, 2009 | 02:28 PM
  #71
DG Motors's Avatar
Gotcha...Everything is in order! Thanks!
Old Oct 6, 2009 | 03:19 PM
  #72
blackdemon's Avatar
Saw this car this past weekend. Looking nice pete. Keep us updated.
Old Oct 6, 2009 | 03:50 PM
  #73
DannyK24's Avatar
So sick.
Old Oct 6, 2009 | 05:16 PM
  #74
Jonnyblaze81's Avatar
This car is gonna be bad a$%!!! Im gonna have to come down and check this thing out in person. Teejay you got some big ones, good luck and mad props
Pete/ Eric, im still selling my ix 35r kit, once this thing sells, we are going to be doing something similar, but with a built bottom end
Old Oct 6, 2009 | 06:03 PM
  #75
Excalibur's Avatar
Did this kit come with the "mini" wga's? Were there any clearance issues if not?
