Philadelphia's Classiest Drunkards
Old Feb 23, 2011 | 10:57 AM
  #17866
AlwaysinBoost's Avatar
Originally Posted by colonelfox
The mini batteries suck from what I've experienced and seen. They don't last as long and they have a really limited amount of cranks. Some get lucky like Marc, but more don't especially in hot or cold climates. If the car doesn't want to start easily that thing is drained fast. I have never like them. That's just my opinion. There's as many arguments for as against, but I took the relocation side.
I'm a lucky SOB because the PC680 in my EVO lasted longer than the Optima red top in my Z06. Heck, even the cheap little Deka battery I'm running now started the car up after almost 3 months of sitting in the cold (between Oct-Dec) when my car was @ Adams house.
IMO if you're going to drive the car on a daily basis a mini will do fine. Even driving only once a week or every other week should still be good.
Old Feb 23, 2011 | 10:58 AM
  #17867
PeteyTurbo@KHC's Avatar
Originally Posted by igo4bmx
so where should i go to get my rotors cut. they are warped (rotorpros FTL)
been two years and about 15k miles...
wal mart
Old Feb 23, 2011 | 11:00 AM
  #17868
igo4bmx's Avatar
Originally Posted by AlwaysinBoost
don't cut your rotors, replace them.
they shouldn't be warped already, you sure its not pad transfer?
how can you tell?
they are slotted btw,,,
Old Feb 23, 2011 | 11:04 AM
  #17869
evremonde's Avatar
why not?
I regret not getting the deka because of this. But maybe with my luck i would have been stranded somewhere with it.
who knows.
Old Feb 23, 2011 | 11:06 AM
  #17870
I'm not a brake rotor expert (chu prolly is), but from the reasearch I've done on the subject 'warping rotors' is a very common term used to describe a couple of different problems none of which are actually warped rotors.
What are the symptoms that make you believe they are warped?
I think you can see the build up of pad material on teh discs. Steel wool, a brillo pad and or some brake clean should remove the build up. I would try that and also try using a TQ wrench in a star pattern when you reinstall the wheels.
Old Feb 23, 2011 | 11:12 AM
  #17871
Tims2006MR's Avatar
Thinking about heading down to atco on sunday if any of you guys are interested. Hoping i can pull an 11 sec pass out of it
  #17872
Originally Posted by evremonde
why not?
I'm not an engineer, so someone please correct me if I 'splain this wrong, but all a rotor does is take heat (energy) and dissipate it. the more mass the rotor has the more heat its capable of absorbing and potentially transferring. when you take material away from the rotor you are decreasing its service life and limiting its ability to do its job (transfer heat).
Old Feb 23, 2011 | 11:14 AM
  #17873
someone please tell me if I'm starting to sound like a forum know it all and I'll gladly STFU. I really hate those types of people. with the battery and rotor topic lately I'm starting to feel like I'm playing that roll.
  #17874
grillpt's Avatar
This. I would try cleaning them and rebedding the pads.
Originally Posted by chu
I had the original battery from 03 until last March when I changed to a mini...
Thats about how long mine lasted, maybe April.
how can you tell?
Can you even cut slotted rotors? I thought you couldn't for some reason...?
Old Feb 23, 2011 | 11:15 AM
  #17875
I am interested... gotta see how the weekend plays out first though. I probably won't know for sure until Satruday night.
  #17876
grillpt's Avatar
Hey AlwaysinBoost,
STFU!
Regards,
grillpt
Old Feb 23, 2011 | 11:17 AM
  #17877
Tims2006MR's Avatar
hopefully the wind isnt too bad either
Old Feb 23, 2011 | 11:20 AM
  #17878
evremonde's Avatar
True, the more material the better at managing heat the rotor is. If this was competition, then sure, just chuck the old rotor. For a DD there is no reason to buy now discs if you only have small groves. Once you hit a certain width you will want to replace to rotor
Replacing rotors also shortens their service life, lol
Old Feb 23, 2011 | 11:21 AM
  #17879
hopefully. Sunday looks like the nicest day of the weekend...
I'm hoping to best my 12.0 @ 113 with the addition of cams & the IX turbo since my last trip back in 07, lol. An 11 second slip on pump gas would make me happy, but I know I'm hella rusty and my toon needs some work... those are the excuses I'm sticking too.
Old Feb 23, 2011 | 11:25 AM
  #17880
shuttlegoose's Avatar
Marc, my synapse bov has been the greatest mod for me in all honesty. But then again, I've had more problems than most people with flutter and surge. I havnt really gone from a high gear low rpm that much because I had to teach myself to drive around that because of all the problems I had before. I can go from 4th around 1500rpm and ease into the gas and I get no flutter or any issue that I got every time with my stock bov. Josh and I were stumped for months. Put on the synapse and I havnt looked back
