Philadelphia's Classiest Drunkards
Old Mar 14, 2011 | 10:40 AM
  #18991
AlwaysinBoost's Avatar
I believe he did buy a new kart, but I'm not sure. Its hard to keep up with all the swapping he does.
  #18992
psushoe's Avatar
Originally Posted by chu
I dont think you're going to clear the Brembos with a 15mm spacer. The RPF1 in 18x9.5 +38 requires a minimum of 20mm to clear the brakes. I'll bring my 20mm just in case. Are the NT03 +27 or +40?
Thanks! 15mm is based on feedback from Adam and others that run these wheels for autox. They better fit!
Originally Posted by AlwaysinBoost
I'm going to see Adam on Satruday @ NJMP. Worse case, if Adam can grab my spacers from Jimmy and bring them with, I can swap at the track and give him my 15mm spacers to give to you on Sunday.
Cool. I'll talk to Adam and see what he can do.
Old Mar 14, 2011 | 10:43 AM
  #18993
Aaron, keep in mind the center bore diameter for those Enkie's is larger than OEM... so a spacer made for those wheels will not fit OEM.
Old Mar 14, 2011 | 10:54 AM
  #18994
grillpt's Avatar
I run those wheels for street and autox, I use a 20mm spacer, 15mm no bueno.
That too, have to get the right hubcentric ring, as its larger than oe.
Old Mar 14, 2011 | 11:29 AM
  #18995
psushoe's Avatar
I can't run oem wheels anyway. Stoptech's require a 18" minimum. I can run the +27 nt03's up front with no spacer and have plenty of clearance. A +38 rpf1 with a 15mm spacer is effectively +23. The spokes are a different shape, but hopefully it's enough to clear. Chu might be my savior though .
Old Mar 14, 2011 | 11:49 AM
  #18996
chu's Avatar
chu
Oh...you didn't mention the car had different brakes. Maybe 15mm WILL work. Here's my experience with both sets of wheels, running stock Brembos:
NT03: 18x9.5 +27 requires 10mm spacers in front. This setup runs 255 tires, and minor rolling in back
RPF1 : 17/18 x 9.5 +38 requires 20mm spacers in front. Runs up to 285 with rolling in the back.
I take it those StopTechs give more outter clearance, which is why you're not running spacers on the NT03, and only need +15mm for the RPF1. In any case, I will bring my 20mm spacers for you in case you need them!
Old Mar 14, 2011 | 11:58 AM
  #18997
psushoe's Avatar
Interesting. Didn't know the nto3 needed a 10mm on stock brakes.
If you need a 20mm on a 9.5" wide rpf1, it would make sense that a 10" wide would only need 15mm. 0.5"=12.7mm. From the wheel centerline, it would be 6.35mm wider in each direction, meaning the spokes would be 6.35mm farther from the brakes. 20mm-6.35=13.65mm ... round to 15mm spacer.
Of course, this is all theoretical. The real test is on the car this weekend. Knowing the stoptech's seem to give a little extra room, I feel better
Old Mar 14, 2011 | 12:04 PM
  #18998
you should use that car for what Adam built it for
Old Mar 14, 2011 | 01:14 PM
  #18999
dek0026's Avatar
i got my scca card. i registered for autox. i got rid of the retarded number and ended up with just #1. sweet! now how do i keep that as my number?
Old Mar 14, 2011 | 01:24 PM
  #19000
^ don't let your membership expire, lol.
Old Mar 14, 2011 | 01:32 PM
  #19001
dek0026's Avatar
so I'm 1 SM now? can i go get some numbers made?
Old Mar 14, 2011 | 01:38 PM
  #19002
you going to run SM or T-SM? I would do T-SM if I were you, that way you'll be classed with people who are on the same type of tire.
Old Mar 14, 2011 | 02:49 PM
  #19003
psushoe's Avatar
I'll eventually get it back on the track. For now, my motorsports goal is to become competitive in a national SM field (tours and pros) and eventually trophy at Nats.
Old Mar 14, 2011 | 04:34 PM
  #19004
grillpt's Avatar
If everyone that was on a street tire ran t-sm, the sm field would be like 2-3 cars.. just sayin.
Esp if your not campaigning your car.
Old Mar 14, 2011 | 05:13 PM
  #19005
dek0026's Avatar
i don't care enough to do that.
you're probably uncomfortable running the same class as me this season.
i'm going to rape each course with my 75psi turbo spool and 200 shot of nos.
