Philadelphia's Classiest Drunkards
Old May 19, 2011 | 05:34 AM
  #22501
AlwaysinBoost's Avatar
signing up for NJMP w/Trackdaze June 30th & July 1st tonight... just sayin.
Old May 19, 2011 | 05:38 AM
  #22502
chu's Avatar
chu
I'll be signing up for that. Just have to wait until after my vacation!
Old May 19, 2011 | 05:42 AM
  #22503
you are becoming a track *****...
Old May 19, 2011 | 06:02 AM
  #22504
chu's Avatar
chu
Nah ahhh... I'm one track day behind Pete...
Old May 19, 2011 | 06:06 AM
  #22505
dek0026's Avatar
I think I might be on my way too.
I just ordered another set of front pads just to have. It will be 2-3 events until I need to think about them but I will be good to through into the box of stuff I take to the track.
Old May 19, 2011 | 06:17 AM
  #22506
grillpt's Avatar
Originally Posted by evremonde
i do. when?
good luck.
me too, but i need a bigger turbo first.
*specs took one day to get here! yay.
You never said what size you got?
I think I'm gonna be good for the Shattenbaum event on the 16th-17th. I've got some monies in my paypal I can use towards it. If i do that event though, no way I can do trackdaze later in the month.
Dude, you probably didn't even put the slightest dent in your first set. I have 17sessions on mine and I think they'll be good for another 2 days. I'm gonna swap them out this weekend, so i guess Ill find out them. If anything, I'm gonna need tires...
Old May 19, 2011 | 06:19 AM
  #22507
I didn't mean it in a bad way.
what pads did you go with? we gotta get you braking correctly so your pads don't wear so much... you should still have like 90% left after only one day, lol.
Old May 19, 2011 | 06:26 AM
  #22508
dek0026's Avatar
It looks like I wore a good amount off in just that one day. I still have plenty of life on them but I figured it wouldnt hurt to have a extra set so I'm not scrambling two days before an event to replace them.
Also I have a lot of things to work on. Brakes are one thing. Tim didn't say anything about my braking on Friday. That's not to assume I was doing it right. It was probably because there were bigger and better things to deal with.
If I were an instructor I'd be pretty nervous about some noob whipping me around a track at 100+mph their first time out. I'd probably prefer them to over use their brakes for my sake!
Old May 19, 2011 | 06:27 AM
  #22509
btw, in the for what its worth catagory, I'm not sure if I'm totally in love with the XP12s. I still need to pull them off to measure how much pad I used over the last 3 track days but I have a feeling the wear is going to be greater than the XP10s and I didn't notice that they were any better to justify it... I didn't notice they were any worse either though. The xp12s are supposed to have more initial bite than the xp10s but I felt the opposite. Maybe I'm just not braking hard enough or I need to do a back to back comparo at the track between sessions to really 'feel' the difference.
Only positive thing I did notice over the xp10s is that once they get bedded in they don't make any noise on the street like the xp10s do. That is a plus
Old May 19, 2011 | 06:33 AM
  #22510
dek0026's Avatar
Marc, to answer your question: I'm running the xp10 front and xp8 rear.
Mine make little to no noise. The one passenger rear side makes a small squeak but that's it and they got quieter after transferring some material to the rotors.
Old May 19, 2011 | 06:36 AM
  #22511
chu's Avatar
chu
Marc, are you using them any differently than you were with the XP10s? Like, tried braking later or something. I would at least assume the 12s should last longer since they take heat better.
Since we're talking abotu brakes, I really like the ST43s I used in my last session at NJMP. Only problem was I really needed a more aggressive rear pad to make up for the fronts. I talked to Mark about this at the track. I'd like to try them again at the next event, but I may not get to.
Old May 19, 2011 | 06:40 AM
  #22512
grillpt's Avatar
My XP10's made a ton of noise after Monticello, not so much after the last 3 days in Jersey.
Old May 19, 2011 | 06:44 AM
  #22513
you lucky. every set of xp10's I've had squeal like a pig getting raped in the bum.
I didn't adjust my technique as far as I was aware of. Only thing different was for the beginning of the first two days w/NNJR PCA I was on them more because I was stuck behind traffic and they were braking WAY too much causing me to overbrake too. It was also wet the first two sessions so I wasn't on them as hard & short as I like to be.
my 'thinking' is that the XP10's have more than enough torque for the 255 Z1's I'm running. so stepping up to an even more aggressive pad probably didn't yeild any better results because I wasn't able to take advantage of the extra stopping power due to my setup. thats my uneducated guess anyway.
Old May 19, 2011 | 06:48 AM
  #22514
grillpt's Avatar
^ All the more reason to go to a 9.5" wheel and 265's.
  #22515
