Philadelphia's Classiest Drunkards
Old Jun 16, 2011 | 09:06 AM
  #23686
Tims2006MR's Avatar
Originally Posted by Mr. MR
How did you do it? I have done that process a few times, but not the Mitsu way, the ghetto driveway repair method. Basically you just turn ignition on without starting, once ACD pump starts running you crack bleed valve open to pump air out. It worked on my car more than once, so I think its a sound method. Obiviously its a 2 person job.
I am one of the few who managed to blow their ACD pump, Adam Fuhs helped me replace the pump at Fed Ex field event if I remember correctly..
I went wot then turned the key on, waited 10 sec for the pump to engage. I don't think its working because im only getting a dribble out of it. Any one have any ideas how to properly do it? Im tired of my 3 lights being on and im hoping its only air in the system.
Old Jun 16, 2011 | 09:34 AM
  #23687
Mr. MR's Avatar
If there is air in there you have to do it quite a few times. You could have a wasted ACD pump. Mine was bad, we installed one known to work, bled as I said previously and no lights.
I just sent Adam a text to clarify how he did mine...
Old Jun 16, 2011 | 09:38 AM
  #23688
robertg's Avatar
Another Buschur thread on lock-down
https://www.evolutionm.net/forums/ev...attitudes.html
Old Jun 16, 2011 | 09:39 AM
  #23689
Tims2006MR's Avatar
^ thanks, apparently they wont cover it on my aftermarket warranty.
Old Jun 16, 2011 | 09:40 AM
  #23690
Mr. MR's Avatar
I forgot the gas pedal needs to be floored. So it goes like this:
Turn ignition on, do not start engine though
Press gas pedal all the way down
ACD pump will engage which is when you crack bleed valve
Air/fluid should start coming out
I would repeat the bleed process a few times to make sure you get all the air out.
If that fails find a used ACD pump out of a totaled Evo, new they are $$$
Old Jun 16, 2011 | 09:43 AM
  #23691
Mr. MR's Avatar
Do not bother Autoxing with bad ACD pump, your car will be front wheel drive anytime you turn the steering wheel. Car will launch in a staight line, but any steering input puts all power to front wheel. I was in Devens when that happened and fixed it at Fed Ex field, pretty sure that's what happened. This was at least 3-4 years ago so I am a little foggy on exactly how it went down.
Old Jun 16, 2011 | 09:54 AM
  #23692
honda-guy's Avatar
here's how i did mine from this post.
https://www.evolutionm.net/forums/ev...eding-acd.html
Disconnect Solenoid and sensor
Activate the solenoid hardwired and open bleeder ( attach transparent tube, open slowly ) same time for about 6 to 7 seconds
Close bleeder, disconnect solenoid.
Reattach connectors, Ign on , throttle activate pump.switch off ignition after pump stops
repeat these steps until no more air is coming.
Refill reservoir as needed with fresh ATF SPIII
Old Jun 16, 2011 | 09:55 AM
  #23693
psushoe's Avatar
I remember you complaining about driving a fwd car when that happened. I think I said something along the lines of "welcome to the club"
Old Jun 16, 2011 | 10:18 AM
  #23694
Tims2006MR's Avatar
hmm my car still over steers with power
thanks, im going to try this Saturday when i flush my brakes
Old Jun 16, 2011 | 10:23 AM
  #23695
steinvb12's Avatar
Originally Posted by robertg
I have Brembo pads and rotors on the Civic and they stop the car like a tree.
Anyway, this is funny:
http://offer.ebay.com/ebaymotors/ws/...m=350466564485
Good stuff. My wife would be pissed too if I tried to spend $50K!
Originally Posted by Jeffroevoix
Hai Dan!
Hows Jack?
Chu does your club risque sponsorship include pit girls?
Where you been brotha? Any turkeys this spring? My dad shot a nice size gobler with a 10" beard. Last day too...
Old Jun 16, 2011 | 10:42 AM
  #23696
chu's Avatar
chu
What else is new? We had this convesation before, and you, Jim, and myself hunged out at Rock Bottom.
Old Jun 16, 2011 | 10:49 AM
  #23697
Mr. MR's Avatar
Great info you found there. This way is a little more involved but it sounds correct. Funny that we bleed it my way with no lights on and my stuff working correctly for a long time now, like years. I think I want to try the ECU Scan way with the bleed feature, Marc or Adam will have to help me do this.
Old Jun 16, 2011 | 11:26 AM
  #23698
Jeffroevoix's Avatar
I've been hiding. No turkeys, had a good season just nothing to show for it.
Old Jun 16, 2011 | 12:51 PM
  #23699
AlwaysinBoost's Avatar
Sup bishes. Having a good time @ njmp... Couple highlights:
Grillpt just got solo'd
There is an alleged 900whp cobra in my group who I got some good video of trying to fight me off
Dan destroyed a c6 z06 in his stock e36 m3
The track is very loose
Thankfully everyone is pointing us by
Old Jun 16, 2011 | 01:19 PM
  #23700
chu's Avatar
chu
Congrats Pete....but didn't he get solo'd before?
