Philadelphia's Classiest Drunkards
Old Aug 9, 2011 | 05:53 AM
  #26176
evremonde's Avatar
Originally Posted by grillpt
To do what? I don't suggest cutting them...
why not? how else does one fix a uneven rotor?
Old Aug 9, 2011 | 06:04 AM
  #26177
igo4bmx's Avatar
usually it's not the rotor's surface but more of pad accumulation- Once I put on a set of RacingBrake ET500™- the pulsating went away!
  #26178
Mr. MR's Avatar
Most times brake pulsing is just pad material build up on rotor. I have cured this on the Evo by rebedding the brakes per brake manufacturers bed in procedure. It is worth a try before you pay someone to look at it.
Pete, I agree that cutting rotors is a waste, you can buy cheap Centric brand replacement rotors for the cost of getting rotors cut.
Old Aug 9, 2011 | 06:08 AM
  #26179
Mr. MR's Avatar
Originally Posted by honda-guy
or the boost hit so hard i went into warp drive. i need to get me some warp drive proof windshield
My windshield is cracked too. I researched getting a replacement, if you get the light windshield for the Evo its around $600. If you get a regular Lancer windshield it is $225 area. The lancer windshield is much heavier than the Evo's from what I understand.
If you figure out how to get a replacement windshield at a reasonable cost let me know please. I am sick of the crack in my line of site now for 2 years.
Old Aug 9, 2011 | 06:11 AM
  #26180
AlwaysinBoost's Avatar
Safelite replaced my evo windshield twice now. I think it was only like $170 installed and they used an EVO windshield not a lancer one.
who all is coming to P&P this weekend?
Old Aug 9, 2011 | 06:18 AM
  #26181
grillpt's Avatar
Originally Posted by InitialE
To diagnose the brake pulsing problem and then figure out what can be done about it. I think it is uneven brake pad deposition on the rotors (probably front).
This.
Old Aug 9, 2011 | 06:26 AM
  #26182
chu's Avatar
chu
Take rotors off, clean up really well, reinstall, rebed pads.
Old Aug 9, 2011 | 06:34 AM
  #26183
Tims2006MR's Avatar
me!
My brakes are pulsating. Can you guys recommend a good brake shop in the King of Prussia area?
Some brake clean and 80 grit sand paper are going to be your friend. Or go to rockauto and get some centric rotors if you do not feel like cleaning yours up
Old Aug 9, 2011 | 06:43 AM
  #26184
Mr. MR's Avatar
You sure they used an evo windshield? Because when I called a windshield place and questioned the windshield they were using the same windshield for both Lancer and Evo. The actual Evo windshield is NOT easy to find. Call Safelight and ask them about both cars and you will see. Its just like the friqqin replacement ball joints part #'s that are listed on Moog are the same for both Lancer and Evo.
Old Aug 9, 2011 | 06:44 AM
  #26185
dek0026's Avatar
Track pads are really good at cleaning your rotors, especially if you have street pad material on them already.
Old Aug 9, 2011 | 06:51 AM
  #26186
Originally Posted by Tims2006MR
me!
Nguyen!
IIRC there is a serial number or some code on the corner of the windshield that differentiates the EVO glass from the lancer glass. i made sure my replacement glass was the correct one when it was installed. this was about 4 years ago though so maybe things have changed since that time. Honestly though dude, do you really think it matters? I mean we're talking about what, maybe 10# difference in exchange for a stronger glass. I wouldn't really care that much but I'm not looking for every weight savings possible either.
Old Aug 9, 2011 | 06:54 AM
  #26187
Mr. MR's Avatar
Nguyen!
Total blasphemy! to think you were once a racer, of course it matters!!! to me
Old Aug 9, 2011 | 07:07 AM
  #26188
wat you mean 'were once a racer'... thems fighten words!
you coming to P&P so I can *****-slap you in your own car?
Old Aug 9, 2011 | 07:18 AM
  #26189
dek0026's Avatar
I'm taking my wife station wagon to P&P for ***** and gigs
Old Aug 9, 2011 | 07:37 AM
  #26190
honda-guy's Avatar
Lancer windshield is 3 lbs heavier than evo. I replaced mine at beginning of year
