Philadelphia's Classiest Drunkards
Old Aug 19, 2011 | 11:03 AM
  #26746
AlwaysinBoost's Avatar
you shouldn't be. AWD and star specs FTN!
Old Aug 19, 2011 | 11:16 AM
  #26747
grillpt's Avatar
If only I had a new set...
On the car.
Old Aug 19, 2011 | 01:37 PM
  #26748
06RS's Avatar
I just got a set of Conti extremecontact DWS's for the Audi. I drove them in what was close to a flash flood yesterday, and they were very solid. They Conti Pro's that were replaced had around 1/32" of tread left.
They would be boring on an Evo, but they appear to be nice tires for all-seasons.
Old Aug 20, 2011 | 09:48 AM
  #26749
Tims2006MR's Avatar
you guys have some great weather for njmp. Im bored at work so im making a removable fog light set up.
Old Aug 20, 2011 | 06:33 PM
  #26750
grillpt's Avatar
Hai!
Old Aug 20, 2011 | 06:49 PM
  #26751
psushoe's Avatar
Hoi!
Old Aug 20, 2011 | 06:57 PM
  #26752
grillpt's Avatar
Shoe, when are you coming out to NJMP?
Fo realz!
Old Aug 21, 2011 | 05:35 PM
  #26753
Mr. MR's Avatar
Howdy
WTF is up with PCD this weekend?!
BORING I come in here to be entertained... NOT entertaining this weekend fo sure
Nice that it rained all day and I got nothing cleaned for the big trip, truck is dirty inside and out. Car is just plain dirty ... I still have to get Trans fluid changed, tires swapped and I guess I am going to Allentown to pick up some E85, even though E85 is everywhere in Nebraska.
I did fix my power door lock (sort of) on truck, got my diff fluids changed (so ripped off by this place by my house, sick of them, $250 to change diff fluids... really). Tires and wheels are in truck to run over to Just Tires tomorrow. So I guess I am almost ready.
Other news is Friday's Thunderstorms blew my Xfinity Modem / router but no other equipment? Strange so I had to goto Comcast service center in norristown and got a replacement, except my other one was nicer, had built in router. The replacement modem is a piece but it works and I had a router, so no bigs....
Old Aug 21, 2011 | 05:41 PM
  #26754
dek0026's Avatar
Mike, that same storm blew out a cable and router (verizon) too. My garage door opener isn't work either. I don't know if it needs a fuse or what. I need someone that knows about this crap too look at it.
Meanwhile BMW CCA event was fun and interesting at the same time
Old Aug 21, 2011 | 07:35 PM
  #26755
igo4bmx's Avatar
does the door opener not even try? if you have infrared sensors to see if anything is under the door, make sure those face each other or the door won't open.
Old Aug 21, 2011 | 08:21 PM
  #26756
Mr. MR's Avatar
Usually when there is something in the beam my garage door opener light flashes. You can tell if there is power, which I assume Dan has none. I would try looking it up in manual to see if there is any kind of fuse. Also make sure you have power to outlet opener is plugged into. If none of above sounds like a trip to sears is in order to purchase a new one.
Old Aug 22, 2011 | 03:58 AM
  #26757
psushoe's Avatar
Fo realz!
I've been to NJMP... to autox in the SJR winter series!
Old Aug 22, 2011 | 05:31 AM
  #26758
dek0026's Avatar
James and mike,
When I push the button to open it the light clicks on but the opener doesn't do anything else. It also clicks the light on when I cross over the beam too. Nothing is in the way but I'll check again.
I'll look in the manual to see if there is a fuse to replace in it.
Old Aug 22, 2011 | 05:33 AM
  #26759
dek0026's Avatar
Where was the autox set up? One of the BMW guys was saying yesterday about how the autox runs out over turn one at lightning and into the skid pad or something. Or maybe that was rallycross.
Old Aug 22, 2011 | 05:34 AM
  #26760
why garage door no work?
because racecar.
lame I know, but its all I gots this morning. James where is the funny @?
